New project, litehm2: a hostmot2 port to linsn rv901t
- tuxcnc
- Thank you received: 60
03 Jun 2023 12:51 #272824
by tuxcnc
Replied by tuxcnc on topic New project, litehm2: a hostmot2 port to linsn rv901t
I did some investigation, and it seems that Litex does not support Spartan 6 (RV901T board) and never will supports...
So, there are two solutions :
1. Do not use Litex.
2. Do not use RV901T.
Ad. 1
Source can be rewriten to Xilinx ISE 14.7 only project.
Good source compiled with good tools must gives good firmware.
Ad. 2
Source can be rewriten for Lattice and Colorlight 5A-7B board.
Litex support Lattice well.
There are some hardware problems (watchmaker's job with SSOP and complicated write to flash) but it can give good result.
RV901T + Litex = too many problems.
"It works for me" does not mean anything and is not a consolation when it not works for you.
Ad. 1
Ad. 2
- sensille
- Thank you received: 17
03 Jun 2023 13:08 #272825
by sensille
github.com/enjoy-digital/litex/wiki/Cores-Ecosystem
Look for "Spartan-6".
I can't do more than offering my help.
Replied by sensille on topic New project, litehm2: a hostmot2 port to linsn rv901t
- IlyaKw
- Thank you received: 3
03 Jun 2023 14:38 #272834
by IlyaKw
Replied by IlyaKw on topic New project, litehm2: a hostmot2 port to linsn rv901t
On what basis did you come to that conclusion ?I did some investigation, and it seems that Litex does not support Spartan 6 (RV901T board) and never will supports...
- IlyaKw
03 Jun 2023 14:41 #272835
by IlyaKw
Use it as you wish at your own discretion.Thanks for the clear instructions. I will link to this post from the README, if that's okay.
- tuxcnc
03 Jun 2023 15:19 #272836
by tuxcnc
You have got good idea, but (in my opinion) you chose bad way.
Leave Litex, or leave RV901T.
It is about 750 (seven hundreds and fifty warnings !!!).
I never will believe it can give good firmware.
You can.
I count warnings produced by compilation process.
- sensille
11 Jun 2023 11:23 #273337
by sensille
Most warning in Xilinx are not an indications for real problems. Xilinx is infamous for the number of warnings their tools generate. Even if you just use their provided cores you can easily end up with more warnings.
Most of them are just informational, like "look, I was able to optimize your circuit here!". Or unused connections.
The hard task is to find the real warnings in there. The xilinx IDE offers tons of filter capabilities for that.
- tuxcnc
11 Jun 2023 16:26 #273353
by tuxcnc
Well, I bought two RV901T, so I will try.
But I'm not an optimist...
- sensille
11 Jun 2023 23:48 #273368
by sensille
There migh be an issue with an overfull FPGA. If you give me the board.conf you are trying to build I can build and test it myself.
- tuxcnc
13 Jun 2023 13:50 #273504
by tuxcnc
- tuxcnc
18 Jun 2023 05:01 #273773
by tuxcnc
It is another good reason why you should replace RV901T by 5A-75B.
I confirm, I tried, a more complex firmware do not fit in Spartan 6.There migh be an issue with an overfull FPGA.
Time to create page: 0.142 seconds
