New project, litehm2: a hostmot2 port to linsn rv901t
28 Jun 2023 17:11 - 28 Jun 2023 17:13 #274407 by sensille
I managed to reduce the footprint of the design and pushed an update.
It needs two patches to litex/liteeth:
github.com/sensille/litex/tree/tx_write_only and
github.com/sensille/liteeth/tree/tx_write_only
I also reduced the system clock from 100 to 80MHz, which should still be plenty. Before, it sometimes slightly missed timing closure, now it is solid.
Last edit: 28 Jun 2023 17:13 by sensille.
The following user(s) said Thank You: tommylight, xu
29 Jun 2023 11:07 #274439 by xu
Brush into rv901t_stock__example_in_initial.bin and ping10.10.10.10 can pass
Then mesaflash --addr 10.10.10.10 --device ether --write rv901t_stock__example_in_initial.bit --fix-boot-block
halrun -I -V HAL.hal
cnc@debian:~/linuxcnc/configs/litehm2_6040$ halrun -I -V HAL.hal
HAL: initializing hal_lib
HAL: initializing component 'halcmd1542'
smalloc_dn: shmem available 1048184
HAL: component 'halcmd1542' initialized, ID = 02
HAL: removing component 02
HAL: releasing RTAPI resources
HAL: component 02 removed, name = 'halcmd1542'
/usr/bin/rtapi_app load hostmot2
Note: Using POSIX realtime
HAL.hal:1: Component 'hostmot2' ready
HAL.hal:1: Program '/usr/bin/rtapi_app' started
smalloc_up: shmem available 1048071
HAL.hal:1: Realtime module 'hostmot2' loaded
/usr/bin/rtapi_app load hm2_eth board_ip="10.10.10.10" config=" num_encoders=0 num_pwmgens=0 num_stepgens=0 sserial_port_0=0000xx"
HAL: component 'halcmd1542' initialized, ID = 06
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 24:1f:83:30:66:de
hm2_eth: Unrecognized ethernet board found: litehm2 -- port names will be wrong
hm2_eth: discovered litehm2
hm2/hm2_lite.0: Low Level init 0.15
hm2/hm2_lite.0: 72 I/O Pins used:
hm2/hm2_lite.0:     IO Pin 000 (??-01): IOPort
hm2/hm2_lite.0:     IO Pin 001 (??-03): IOPort
hm2/hm2_lite.0:     IO Pin 002 (??-05): IOPort
hm2/hm2_lite.0:     IO Pin 003 (??-07): IOPort
hm2/hm2_lite.0:     IO Pin 004 (??-09): IOPort
hm2/hm2_lite.0:     IO Pin 005 (??-11): IOPort
hm2/hm2_lite.0:     IO Pin 006 (??-13): IOPort
hm2/hm2_lite.0:     IO Pin 007 (??-15): IOPort
hm2/hm2_lite.0:     IO Pin 008 (??-17): IOPort
hm2/hm2_lite.0:     IO Pin 009 (??-19): IOPort
hm2/hm2_lite.0:     IO Pin 010 (??-21): IOPort
hm2/hm2_lite.0:     IO Pin 011 (??-23): IOPort
hm2/hm2_lite.0:     IO Pin 012 (??-25): IOPort
hm2/hm2_lite.0:     IO Pin 013 (??-27): IOPort
hm2/hm2_lite.0:     IO Pin 014 (??-29): IOPort
hm2/hm2_lite.0:     IO Pin 015 (??-31): IOPort
hm2/hm2_lite.0:     IO Pin 016 (??-33): IOPort
hm2/hm2_lite.0:     IO Pin 017 (??-35): IOPort
hm2/hm2_lite.0:     IO Pin 018 (??-37): IOPort
hm2/hm2_lite.0:     IO Pin 019 (??-39): IOPort
hm2/hm2_lite.0:     IO Pin 020 (??-41): IOPort
hm2/hm2_lite.0:     IO Pin 021 (??-43): IOPort
hm2/hm2_lite.0:     IO Pin 022 (??-45): IOPort
hm2/hm2_lite.0:     IO Pin 023 (??-47): IOPort
hm2/hm2_lite.0:     IO Pin 024 (??-01): IOPort
hm2/hm2_lite.0:     IO Pin 025 (??-03): IOPort
hm2/hm2_lite.0:     IO Pin 026 (??-05): IOPort
hm2/hm2_lite.0:     IO Pin 027 (??-07): IOPort
hm2/hm2_lite.0:     IO Pin 028 (??-09): IOPort
hm2/hm2_lite.0:     IO Pin 029 (??-11): IOPort
hm2/hm2_lite.0:     IO Pin 030 (??-13): IOPort
hm2/hm2_lite.0:     IO Pin 031 (??-15): IOPort
hm2/hm2_lite.0:     IO Pin 032 (??-17): IOPort
hm2/hm2_lite.0:     IO Pin 033 (??-19): IOPort
hm2/hm2_lite.0:     IO Pin 034 (??-21): IOPort
hm2/hm2_lite.0:     IO Pin 035 (??-23): IOPort
hm2/hm2_lite.0:     IO Pin 036 (??-25): IOPort
hm2/hm2_lite.0:     IO Pin 037 (??-27): IOPort
hm2/hm2_lite.0:     IO Pin 038 (??-29): IOPort
hm2/hm2_lite.0:     IO Pin 039 (??-31): IOPort
hm2/hm2_lite.0:     IO Pin 040 (??-33): IOPort
hm2/hm2_lite.0:     IO Pin 041 (??-35): IOPort
hm2/hm2_lite.0:     IO Pin 042 (??-37): IOPort
hm2/hm2_lite.0:     IO Pin 043 (??-39): IOPort
hm2/hm2_lite.0:     IO Pin 044 (??-41): IOPort
hm2/hm2_lite.0:     IO Pin 045 (??-43): IOPort
hm2/hm2_lite.0:     IO Pin 046 (??-45): IOPort
hm2/hm2_lite.0:     IO Pin 047 (??-47): IOPort
hm2/hm2_lite.0:     IO Pin 048 (??-01): IOPort
hm2/hm2_lite.0:     IO Pin 049 (??-03): IOPort
hm2/hm2_lite.0:     IO Pin 050 (??-05): IOPort
hm2/hm2_lite.0:     IO Pin 051 (??-07): IOPort
hm2/hm2_lite.0:     IO Pin 052 (??-09): IOPort
hm2/hm2_lite.0:     IO Pin 053 (??-11): IOPort
hm2/hm2_lite.0:     IO Pin 054 (??-13): IOPort
hm2/hm2_lite.0:     IO Pin 055 (??-15): IOPort
hm2/hm2_lite.0:     IO Pin 056 (??-17): IOPort
hm2/hm2_lite.0:     IO Pin 057 (??-19): IOPort
hm2/hm2_lite.0:     IO Pin 058 (??-21): IOPort
hm2/hm2_lite.0:     IO Pin 059 (??-23): IOPort
hm2/hm2_lite.0:     IO Pin 060 (??-25): IOPort
hm2/hm2_lite.0:     IO Pin 061 (??-27): IOPort
hm2/hm2_lite.0:     IO Pin 062 (??-29): IOPort
hm2/hm2_lite.0:     IO Pin 063 (??-31): IOPort
hm2/hm2_lite.0:     IO Pin 064 (??-33): IOPort
hm2/hm2_lite.0:     IO Pin 065 (??-35): IOPort
hm2/hm2_lite.0:     IO Pin 066 (??-37): IOPort
hm2/hm2_lite.0:     IO Pin 067 (??-39): IOPort
hm2/hm2_lite.0:     IO Pin 068 (??-41): IOPort
hm2/hm2_lite.0:     IO Pin 069 (??-43): IOPort
hm2/hm2_lite.0:     IO Pin 070 (??-45): IOPort
hm2/hm2_lite.0:     IO Pin 071 (??-47): IOPort
hm2/hm2_lite.0: registered
HAL.hal:2: Component 'hm2_eth' ready
HAL.hal:2: Program '/usr/bin/rtapi_app' started
smalloc_up: shmem available 996956
HAL.hal:2: Realtime module 'hm2_eth' loaded
HAL.hal:3: setting parameter 'hm2_lite.0.watchdog.timeout_ns' to '5000000'
HAL.hal:3: Parameter 'hm2_lite.0.watchdog.timeout_ns' set to 5000000
HAL: removing component 06
HAL: component 06 removed, name = 'halcmd1542'
HAL: component 'halcmd1542' initialized, ID = 09
/usr/bin/rtapi_app load pid names=pid.x,pid.y,pid.z,pid.s
HAL.hal:4: Component 'pid' ready
HAL.hal:4: Program '/usr/bin/rtapi_app' started
smalloc_up: shmem available 978465
HAL.hal:4: Realtime module 'pid' loaded
HAL: removing component 09
HAL: component 09 removed, name = 'halcmd1542'
mb2hal
HAL: component 'halcmd1542' initialized, ID = 12
mb2hal parse_main_args ERR: wrong number of args
mb2hal main ERR: Unable to parse arguments
HAL.hal:5: waitpid failed mb2hal mb2hal
HAL.hal:5: mb2hal exited without becoming ready
HAL: removing component 12
HAL: component 12 removed, name = 'halcmd1542'
linuxcnc litehm2_6040.ini
and can not open linuxcnc
cnc@debian:~/linuxcnc/configs/litehm2_6040$ linuxcnc litehm2_6040.ini
LINUXCNC - 2.10.0-pre0-1542-g93fccc095
Machine configuration directory is '/home/cnc/linuxcnc/configs/litehm2_6040'
Machine configuration file is 'litehm2_6040.ini'
Starting LinuxCNC...
Found file(REL): ./litehm2_6040.hal
./litehm2_6040.hal:12: waitpid failed mb2hal mb2hal
./litehm2_6040.hal:12: mb2hal exited without becoming ready
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/cnc/linuxcnc_debug.txt
and
    /home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
what do I need to do? Transform rv901t or install any software driver?
29 Jun 2023 11:38 #274442 by sensille
The supplied linuxcnc was only meant as an example. Initially it matched rv901t_4out__3stepgen_2enc_1pwm.conf, but I have modified the litehm2-config slightly since, without updating the 6040 config.
But "mb2hal parse_main_args ERR: wrong number of args" sounds more like a problem with linuxcnc.
Did you build it yourself from linuxcnc/master? mb2hal also has changed a bit since I made the config. It would be best to start with the smallest possible config, or even with halrun first.
29 Jun 2023 13:28 #274448 by xu
My linuxcnc is downloaded from the build robot linuxcnc-uspace_2.10.0~pre0.1542.g93fccc095_amd64.deb 2023-06-19 21:34
You said there would be a patch merged into 2.10
The file rv901t_stock__with_jp4_initial.bin is programmed and uploaded to linsn rv901t can’t be pinged with 10.10.10.10, but the other two firmwares can
29 Jun 2023 13:29 #274449 by xu
sensille 帖子=274442 用户id=33477提供的 linuxcnc 仅作为示例。最初它与 rv901t_4out__3stepgen_2enc_1pwm.conf 匹配,但此后我稍微修改了 litehm2-config,而没有更新 6040 配置。
但是“mb2hal parse_main_args ERR:错误的参数数量”听起来更像是 linuxcnc 的问题。
你是从 linuxcnc/master 自己构建的吗?自从我进行配置以来,mb2hal 也发生了一些变化。最好从尽可能小的配置开始,甚至先从 halrun 开始。
29 Jun 2023 18:45 #274464 by sensille
The error you pasted was about mb2hal, not litehm2. You probably don't need mb2hal. Try to write a very small config.
30 Jun 2023 11:57 #274498 by xu
Thank sensille
Comment out all the output and finally be able to start linuxcnc
Maybe I should modify the circuit of rv901t before running linuxcnc
30 Jun 2023 13:03 #274504 by xu
rv901t_4out__3stepgen_2enc_1pwm, can you do a pre-firmware bit that will contain 6 outputs, 20 inputs, 6 stepgens, 6 encoder interfaces and 2 pwm generators.
The following user(s) said Thank You: Pro_El
30 Jun 2023 13:20 #274506 by sensille
Yes. Did you modify the board in the same way I did?
Do you want differential stepgen?
30 Jun 2023 14:40 #274514 by xu
Thank sensille
Yes, I want differential stepgen, because it can better support servo motors,
I would like to try Ilya Koubatkin's retrofit method first and am also interested in your method
Moderators: PCW, jmelson
