Mesa CT and 7i97T
- B.Reilly01
- Topic Author
- Thank you received: 11
11 Dec 2023 16:40 #287866
by B.Reilly01
Mesa CT and 7i97T was created by B.Reilly01
Are there any updates necessary to the Mesa CT now that the 7i97T is out there? Can I configure as a 7i97 and get away with it?
Thank you,
Thank you,
11 Dec 2023 17:30 #287869
Replied by PCW on topic Mesa CT and 7i97T
A configuration created for a 7I97 will work on a 7I97T
(using LinuxCNC 2.9.1 or >)
but you cannot change firmware with the utility yet (AFAIK)
- flyingbrick
22 Dec 2023 08:44 #288811
by flyingbrick
Replied by flyingbrick on topic Mesa CT and 7i97T
Forgive me, my card has been stuck in customs here for the past two weeks, so trying to learn what I can for when it arrives.
What does your above reply mean to owners of the cards. Its confusing as some people seem to flash their cards before use and some people don't. I do t know why you would need to and why you wouldn't, or how you would if the software does not work
22 Dec 2023 14:23 #288823
You do not need to change the firmware unless you are using a
daughtercard on the parallel expansion port. In that case, you
would need firmware that supports that parallel daughtercard.
The following user(s) said Thank You: flyingbrick
- B.Reilly01
- Topic Author
22 Dec 2023 18:34 #288831
by B.Reilly01
Replied by B.Reilly01 on topic Mesa CT and 7i97T
So I do plan on using a 7i76 on the DB25 expansion.... What do I need to do?
22 Dec 2023 19:17 #288833
You would flash the proper firmware: 7i97t_7i76d.bin
with mesaflash. then run the mesact configuration
utility and select 7I97 and 7I76 daughtercard.
(but don't attempt to change the firmware)
The following user(s) said Thank You: B.Reilly01
- B.Reilly01
- Topic Author
23 Dec 2023 01:09 #288855
by B.Reilly01
When I attempt to flash the firmware I get:
"Unsupported ethernet device 7I97T at 10.10.10.10"
"No 7I97T board found"
makes me believe my mesaflash is out of date, but it says it's the most current version 3.4.6-1
23 Dec 2023 01:31 #288856
3.4.6 is too old to support the 7I97T.
( I think the current version is 3.5.3)
To get the latest, go to
github.com/LinuxCNC/mesaflash
And scroll down to the bottom of the page for build instructions
- flyingbrick
26 Dec 2023 03:41 #289063
by flyingbrick
Hi PCW,
Might be a minor issue (or not an issue at all)
Page 14
"ANALOG SERVO DRIVE INTERFACE The 7I97T provides six channels of +-10V analog servo interface on connector TB5."
Should that instead say TB3?
Page 14
26 Dec 2023 03:58 #289064
Yes, the analog out connector is TB3 (page 10)
I'll fix the manual when I get a chance
