Hardware & Machines
Driver Boards
Mesa CT and 7i97T
Mesa CT and 7i97T
Thank you received: 11
02 Jan 2024 02:54 - 02 Jan 2024 03:03 #289525
by B.Reilly01
I seem to have a problem where my configuration tries to assign the 7i97 pins to the daughterboard (7i76) for analog output.
Thank you received: 4350
02 Jan 2024 14:35 #289567
The spindle pins would be:
hm2_7i76e.0.7i76.0.3.spindir
hm2_7i76e.0.7i76.0.3.spinena
hm2_7i76e.0.7i76.0.3.spinout
and spindle parameters:
hm2_7i76e.0.7i76.0.3.spindir-invert
hm2_7i76e.0.7i76.0.3.spinena-invert
hm2_7i76e.0.7i76.0.3.spinout-maxlim
hm2_7i76e.0.7i76.0.3.spinout-minlim
hm2_7i76e.0.7i76.0.3.spinout-scalemax
You can list all the hardware pins/parameters with:
halcmd show all hm2
(when LinuxCNC is running)
02 Jan 2024 15:20 - 02 Jan 2024 15:21 #289570
by B.Reilly01
In my HAL, Joint 0 analog appears to be assigned to the 7i76, as shown below. My understanding is that the 7i76 doesn't have analog output for joint 0. Regardless, my analog signal wires are in proximity to the 7i97T, not the 7i76. This was configured on the 7i97 tab of MesaCT.# Joint 0 Analog setup
setp hm2_[MESA](BOARD).0.7i76.0.3.analogout0-scalemax [JOINT_0](ANALOG_SCALE_MAX)
setp hm2_[MESA](BOARD).0.7i76.0.3.analogout0-minlim [JOINT_0](ANALOG_MIN_LIMIT)
setp hm2_[MESA](BOARD).0.7i76.0.3.analogout0-maxlim [JOINT_0](ANALOG_MAX_LIMIT)
Last edit: 02 Jan 2024 15:21 by
B.Reilly01. Reason: Clarification
02 Jan 2024 17:47 - 02 Jan 2024 17:52 #289582
by B.Reilly01
Ultimately, I want a configuration that does all of the following:
(See attached table)
Right now I just want a config that launches LinuxCNC and has analog outputs for atleast 1 joint on the 7i97T. I'm working towards the above config, learning HAL along the way. Last time I did this I had PNCCONF for a 5i25/7i77.
I think there's an error in MesaCT that assigns the joints only to a daughterboard for the 7i97.
Last edit: 02 Jan 2024 17:52 by
B.Reilly01. Reason: format
02 Jan 2024 19:27 #289588
I suspect the easiest way to do this currently would be to create a 7I97 configuration and a 7I76 configuration
and merge them
Thank you received: 271
03 Jan 2024 13:44 - 03 Jan 2024 13:46 #289657
by JT
I don't have a 7i97T to test with yet... and I also just realized there is an bug with a 7i97 configuration created with the Mesa CT.
JT
Last edit: 03 Jan 2024 13:46 by
JT.
04 Jan 2024 13:18 #289776
by B.Reilly01
Thanks JT for all your work, I'll wait for an update for the 7i97 bugs and try again. I would say my 7i97T can be your guinea pig, but I'm not very knowledgeable on this stuff and I may be the biggest holdback to getting good info.
The following user(s) said Thank You:
JT
08 Jan 2024 14:05 #290215
by JT
I have a 7i97T arriving today to test with. I "think" Mesa CT is ready to create a configuration for a 7i97T.
JT
10 Jan 2024 13:04 #290358
by JT
The Mesa CT will build a configuration for a 7i97T now, I don't have any hardware connected to it so I can't test that. Let me know if everything works now.
JT
Hardware & Machines
Driver Boards
Mesa CT and 7i97T
Time to create page: 0.092 seconds
