Which Mesa Card Should I Buy?
06 Feb 2024 21:29 #292691
by spumco
Replied by spumco on topic Which Mesa Card Should I Buy?
Thank you for the comment Jon.
Based on that feedback, I think this guide should stay here in the forums so there isn't any unintentional 'preference' conveyed to new users. I'll do my best to compose this in a forum-friendly format.
07 Feb 2024 01:59 #292708
by cornholio
Replied by cornholio on topic Which Mesa Card Should I Buy?
Great work, just for the direct connection (spi), might be an idea for the time being to mention the RPi5 is unsupported at the moment. Wouldn't want anyone to throw money at something that doesn't work yet (grumble grumble grumble).
07 Feb 2024 02:24 #292711
by spumco
How's this for section 4?Great work, just for the direct connection (spi), might be an idea for the time being to mention the RPi5 is unsupported at the moment. Wouldn't want anyone to throw money at something that doesn't work yet (grumble grumble grumble).
- Raspberry Pi
- Pi plugs directly in to a Mesa motherboard via the Pi’s GPIO pins
- NOTE - RPi 5 is not supported for direct plug-in as of 2/2024
The following user(s) said Thank You: tommylight, cornholio
07 Feb 2024 11:58 #292729
Replied by rodw on topic Which Mesa Card Should I Buy?
HAving written a couple of howtos on the forum, I recommend you write your posts in a text editor and past the text into the posts.
I save mine in Google drive. much easier than fighting with the forum editor
for example, my Ethercat sticky has been edited countless times as the environment changes this way.
07 Feb 2024 12:24 #292733
by klopp
Replied by klopp on topic Which Mesa Card Should I Buy?
The guide looks very good, would've really helped me when I got started.
The Raspberrys should also be able to connect via ethernet, don't they? That should also work for the Pi5, so it's not completely unusable.
I'm not really deep into this topic so take my word with a bit of caution, this is just a quick thought that came into my mind.
The "expansion ports" section does explain that the ports might not be compatible with each other, but it doesn't really say which ports are exactly compatible.
Maybe a table like:
|Source|Target|Compatible|Comment|
|26 Pin|DB25|Yes|Needs adapter/custom firmware|
for all possible combinations could help.
Also a quick note that you need to connect ethernet ports directly without a switch, otherwise someone might want to use a PC with only one ethernet port that he needs for internet and tries to combine it with a switch. Same goes for the sserial communication ofc.
Again, these are just my thoughts reading through the draft, other than that it really looks great so far.
Maybe a table like:
The following user(s) said Thank You: tommylight, spumco
07 Feb 2024 12:30 #292734
by spumco
Thanks folks, exactly the sort of feedback I'm after.
I'll edit and repost.
- Thank you received: 5942
07 Feb 2024 12:57 #292735
Replied by tommylight on topic Which Mesa Card Should I Buy?
Just went through the PDF, that is way, wayyyy more than what i was thinking when this adventure started, so this is absolutely and unequivocally deserved:
Spumco, utmost respect, magnificent work!
08 Feb 2024 01:58 #292811
by spumco
Whew...
Let me know if anything is horribly wrong and I'll try to brave the forum editor.
08 Feb 2024 02:24 #292815
I wonder if Tommy could delete a couple of his early posts and the ones where Spumco said delete and then this would be a contiguous read!
Great work!
Great work!
08 Feb 2024 03:37 #292818
by spumco
Thank you Rod. I think that's the plan once Tommy gets to it.I wonder if Tommy could delete a couple of his early posts and the ones where Spumco said delete and then this would be a contiguous read!
Great work!
Time to create page: 0.109 seconds
