Which Mesa Card Should I Buy?
08 Feb 2024 16:29 #292856
by spumco
And you're welcome, thanks for asking.
Replied by spumco on topic Which Mesa Card Should I Buy?
Tommy - I think you can get rid of those 'delete' posts. Any updates can be added to existing posts.Some cleaning done, left some on first page for Spumco just in case, i can delete those later if not needed.
Still no word form PCW, would like to hear what he thinks about all this.
Spumco, thank you for the awesome work.
08 Feb 2024 17:05 #292861
by spumco
Good catch. Edited to REV3.Deleted ... and noticed there are 9 sections, not 10 as the table of content says.
Will do another check after my eyes can see single things again...
- Thank you received: 5942
08 Feb 2024 17:24 #292862
Replied by tommylight on topic Which Mesa Card Should I Buy?
So all good?
Would a notice about posting questions only related to /info/versions/new boards/combos/use cases/examples/ here be OK?
Everything fits on the first page, that is very good.
I am deleting all my posts gradually to keep this topic clean.
08 Feb 2024 18:45 #292869
by spumco
I'm all good.
I hadn't planned on expanding for additional examples or new boards. If Mesa comes out with some connection scheme significantly different than what's currently available I can see updating or adding to the guide. Otherwise, I'd expect questions to continue being answered in individual threads rather than here.
My hope is/was that this is more of a 'teach them how to fish' thing where new users are provided some context for the LCNC/Mesa jargon. Without context or some non-jargon technical anchor, new users are lost - I know I was.
Might not be a bad idea to start (or just think about) another pinned post "Mesa Card Examples". Create a format, perhaps similar to what I did above, and people can post a summary of their machine for others to use as inspiration. Kind of like HAL-Examples.
08 Feb 2024 19:03 #292870
OK
I have plenty of machines that i can try to summarize there with a picture or two and configs.
Are you thinking of something like, very short:
description of the
-machine
-functionality
-boards used
-maybe explain some decisions
-maybe explain some solutions
-picture of machine
-picture of control box W/mesa
-attach the config just in case
To much?
Agreed.
Nice idea, will you do the honors?
description of the
-machine
-functionality
-boards used
-picture of machine
To much?
08 Feb 2024 21:26 #292883
by spumco
08 Feb 2024 22:17 - 08 Feb 2024 22:19 #292887
by Dean
Replied by Dean on topic Which Mesa Card Should I Buy?
Okay, this thread has been posted at the perfect time. I built a smaller 3-axis CNC gantry router approximately 10 years ago. It's been a super machine and has done all I've asked of it. Over the years I've upgraded the ACME screws to ball screws and and six months ago I replaced all of the guide bearings with linear rails.
Before I go any further, I should say I'm pretty good mechanically, but know just enough electronically to be dangerous and to free the magic smoke on occasion. My machine has used the 5i25 and 7i76 to run the I/O and Parker CompuMotor OEM750's to drive the steppers since the day I built it. Never a problem in all of those years.
Fast forward to yesterday. When I tried to turn on my system, LCNC wouldn't start and threw errors on the debug screen. It didn't take long to figure out that my 24v power supply had failed. So I ordered another from Amazon and received it today. Plugged it in and got a solid 24.0v out. Then, when I connected it into the 7i76 board, it (the power supply) blew. Unfortunately, I haven't a clue how to troubleshoot the board, so I'm looking for a replacement and see that the 7i76 is no longer available.
After reading spumco's great summary and looking at the Mesa site, I guess I settled on the 7i96S. If I understand correctly, this is a stand-alone I/O board that only requires an Ethernet connection back to the host PC. Is this correct? I need to drive three stepper drivers (and maybe a 4th down the road), the analog VFD spindle control and an additional 6 I/O. Pretty simple set up.
If I posted this in the wrong spot, I'm sorry and feel free to move it. Otherwise any comments, advice and/or suggestions will be greatly appreciated.
Thanks,
Dean
Thanks,
Dean
Last edit: 08 Feb 2024 22:19 by Dean. Reason: Sentence structure
08 Feb 2024 22:58 #292891
7i96S is good for 5 drives + spindle with encoder feedback, and if you ever need more IO, a 7i84 will do just fine and very easy to wire in.
Yes it is correct, glad to see this was useful as soon as it got posted!After reading spumco's great summary and looking at the Mesa site, I guess I settled on the 7i96S. If I understand correctly, this is a stand-alone I/O board that only requires an Ethernet connection back to the host PC. Is this correct? I need to drive three stepper drivers (and maybe a 4th down the road), the analog VFD spindle control and an additional 6 I/O. Pretty simple set up.
The following user(s) said Thank You: Dean
08 Feb 2024 23:03 #292892
Don't think i can do a tour to US though, as if i go there i can not come back here for over 6 months till papers are done, i do have US citizenship, i just never went there to actually become one.
P.S.
Later, I am deleting all my posts to keep this clean.
I would gladly, even if you were somewhere in Europe as i might do a tour this spring.Will you finish my lathe for me?
P.S.
09 Feb 2024 02:28 #292905
Replied by rodw on topic Which Mesa Card Should I Buy?
I'm sure Sean won't mind, if I share his 7i96s plasma wiring diagram here. I'm not saying its perfect but I think it covers everything. I would not ground the high voltage side of the THCAD as shown as it adds some AC ripple into the torch voltage.
Spumeco, Now you just need to add one for a mill and lathe
Time to create page: 0.201 seconds
