mesa 7i33 7i37
07 Apr 2024 19:36 #297763
Replied by PCW on topic mesa 7i33 7i37
OUTPUT_SCALE affects almost all PID settings (except offset)
The following user(s) said Thank You: vre
09 Apr 2024 23:13 #297875
by vre
Replied by vre on topic mesa 7i33 7i37
with P=1 / FF1=0.12 was a very good starting point responds very well..
Next is halscope tuning..
Thank you again
Thank you again
11 Apr 2024 15:20 - 11 Apr 2024 15:24 #298003
by vre
This Pin file is correct for 7i80hd+7i33+7i37+7i84 ?
Also how can i use the I/O pins of 7i84 from hal file like 7i37 ?
Is there an example for 7i84 & hal ?
Last edit: 11 Apr 2024 15:24 by vre.
11 Apr 2024 15:28 #298004
Depends on the sserial daughtercard
7i80hd_16_svss8_8.bit or 7i80hd_25_svss8_8.bit
would be correct for a 7I44 daughter card
You can take a look at a pncconf created configuration
to determine 7I84 connections, or just get the 7I84 running
and:
halcmd show all | grep 7i84
and:
11 Apr 2024 16:23 #298006
by vre
I will use this rs422 module www.aliexpress.com/item/4000345846502.html
to connect 7i80hd with 7i84.
7i80hd P3 -> rs422 module -> 7i84
I don't have now the 7i80hd (is on machine) and pncconf doesn't t give me option to choose 7i44 daughtercard.
11 Apr 2024 16:32 #298007
7i80hd_16_svss8_8.bit or 7i80hd_25_svss8_8.bit should still work for that
To create an example hal file with pncconf, you can chose any firmware
with sserial and add a 7I84 (since its just for an example)
Also the
Should work on you existing system as long as you have sserial firmware
and it's wired correctly (and the 7I84 is powered)
Also the
05 May 2024 19:08 #299836
by vre
Something other about hostmot2
In this code:
IOPortTag & x"00" & StepGenTag & x"81", -- I/O 24
IOPortTag & x"00" & StepGenTag & x"82", -- I/O 25
IOPortTag & x"00" & StepGenTag & x"83", -- I/O 26
IOPortTag & x"00" & StepGenTag & x"84", -- I/O 27
IOPortTag & x"00" & StepGenTag & x"85", -- I/O 28
IOPortTag & x"00" & StepGenTag & x"86", -- I/O 29
What are X"83" X"84" X"85" and X"86" pins ?
Also in this code:
IOPortTag & x"00" & SSerialTag & SSerialRX0Pin, -- I/O 48
IOPortTag & x"00" & SSerialTag & SSerialRX1Pin, -- I/O 49
IOPortTag & x"00" & SSerialTag & SSerialTX0Pin, -- I/O 52
IOPortTag & x"00" & SSerialTag & SSerialTXEn0Pin, -- I/O 53
IOPortTag & x"00" & SSerialTag & SSerialTX1Pin, -- I/O 54
IOPortTag & x"00" & SSerialTag & SSerialTXEn1Pin, -- I/O 55
What are SSerialRX0Pin SSerialRX1P SSerialTX0Pin SSerialTX1Pin SSerialTXEn1Pin
pins ?
In this code:
Also in this code:
pins ?
05 May 2024 19:31 #299838
any pin with SSerialTag is a Smart Serial interface pin
(for Smart serial peripherals like 7I83, 7I84s etc)
Stepgen pins:
0x81 is Step/Table0
0x82 is Dir/Table1
0x83 is Table2
0x84 is Table3
0x85 is Table4
0x86 is Table5
Table pins from table2 to table5 are only enabled when
table mode is enabled for a stepgen (so revert to GPIO)
Table
Stepgen pins:
0x81 is Step/Table0
0x82 is Dir/Table1
0x83 is Table2
0x84 is Table3
0x85 is Table4
0x86 is Table5
Table
05 May 2024 20:30 #299841
by vre
Yes i know that is smart serial interface
but why there are rx0 rx1 tx0 tx1 is because of 2 smart serial connections 0 & 1 ?
also what txen does ?
This module has only rx tx inputs not txen www.aliexpress.com/item/1005004250435673.html
For stepgen tag if i want only step dir and enable what pins must define ?
0x81 0x82 0x83 ?
0x81 0x82 0x83 ?
05 May 2024 20:40 #299843
Yes, each sserial pin has a channel number (the are 8 channels per sserial module)
TXen is for RS-485 interfaces (not needed for sserial but required if the interface hardware
needs it)
0x81 is step
0x82 is dir
needs it)
0x81 is step
0x82 is dir
Time to create page: 0.136 seconds
