mesa 7i33 7i37
05 May 2024 20:46 #299844
by vre
Replied by vre on topic mesa 7i33 7i37
which is the enable except step and dir ?
05 May 2024 21:02 #299845
Replied by PCW on topic mesa 7i33 7i37
Not sure I understand...
05 May 2024 21:16 - 05 May 2024 21:18 #299847
by vre
For example pwmgen module except dir and pwm has enable pin
IOPortTag & x"00" & PWMTag & x"81", -- pwm
IOPortTag & x"00" & PWMTag & x"82", -- dir
IOPortTag & x"00" & PWMTag & x"83", -- pwm enable
stepgen has dir step and which is enable ?
Last edit: 05 May 2024 21:18 by vre.
05 May 2024 22:00 #299850
There is no (hardware pin) enable for step/dir since its always driven
06 May 2024 02:53 #299879
by vre
7i37 has 16 in 8 out and it is parallel
7i84 has 32 in and 16 out and it is sserial
Have any other difference ?
Can use 7i84 instead of 7i37 for home-limit switches probe-in estop-in and general I/O
like tool-clamp-out tool-sensor-in ?
06 May 2024 03:27 #299881
Basically they are interchangeable.
The 7I37 Inputs and outputs are a bit more flexible
(they can both sink and source since they are all isolated)
This means more wiring however since there is no common
The 7I84 has only sourcing outputs and sinking inputs
The following user(s) said Thank You: vre
07 May 2024 01:36 - 07 May 2024 01:49 #299987
by vre
With 7i37TA i have tried inputs for home-limit switches and when the switches triggered became TRUE in hal the inverted input (in_not)
This hal config worked with 7i80hd + 7i37TA
net estop-ext <= hm2_7i80.0.gpio.024.in_not
net home-x <= hm2_7i80.0.gpio.026.in_not
net both-x <= hm2_7i80.0.gpio.029.in_not
I have common ground for outputs to all peripherals and driving voltage is 28-29V (<1A current example electrovalves/mini relays) so sourcing outputs is that i want plus double I/O with 7i84..
Which are the names to access from hal the pins of 7i84 connected to 7i80hd ?
hm2_7i80.0.7i84.0.0.output-00
hm2_7i80.0.7i84.0.0.output-00-invert
hm2_7i80.0.7i84.0.0.input-00
hm2_7i80.0.7i84.0.0.input-00-not
Last edit: 07 May 2024 01:49 by vre.
Time to create page: 0.073 seconds
