Re:CHNC-1 Retrofit & Upgrades
13 Jul 2012 00:27 #21859
by BigJohnT
Replied by BigJohnT on topic Re:CHNC-1 Retrofit & Upgrades
LOL, I thought you meant a Dorian tool holder...
- Alloy Craft
13 Jul 2012 00:57 #21860
by Alloy Craft
Replied by Alloy Craft on topic Re:CHNC-1 Retrofit & Upgrades
Rob, I am going to be retrofitting a older CHNC with ac servos an such, but need the get new pulleys and belts, where did you find those? Also I think I am going to be using Mesa cards. What cards did you end up using on this conversion?
thanks.
thanks.
13 Jul 2012 04:15 #21861
by bobinater
Replied by bobinater on topic Re:CHNC-1 Retrofit & Upgrades
sorry john
I should have been more clear with my post as you can tell i sometimes go off on a tangent
when I get excited about something new.
no harm no foul
bob
no harm no foul
bob
13 Jul 2012 11:24 #21870
by BigJohnT
Bob,
I got my belts and o-rings and quad rings from McMaster Carr they are standard off the shelf parts, the pulleys you can get from Hardinge or other sources.
13 Jul 2012 14:50 #21884
by bobinater
Thanks John
I did not get a chance to work on it last night
had to do the domestic thing.
I will do some more on it on saturday and fill you in on the state of things
thanks for all the help this week, I am really glad to be on this forum
Bob
Bob
13 Jul 2012 18:32 #21911
by robh
Replied by robh on topic Re:CHNC-1 Retrofit & Upgrades
where are you?
i am in UK john is in USA so not sure if my help on part locations would be helpfull or not
13 Jul 2012 19:44 #21918
by bobinater
I am in USA (IOWA) but not opposed to ordering from overseas if needed but John did say that the parts are common from mc master carr
the company I work for has an account so ordering from there should not be a problem, I still need to do some troubleshooting to get the air solenoids
working just to test all of the air components, and I am going to do some preventative maintenance anyway.
BOB
BOB
13 Jul 2012 20:05 #21919
by BigJohnT
Do you have the big drive cabinet on the right side viewed from the rear with a bunch of SSR's on a panel? On mine they control the solenoids as well as other things like the light. You should be able to plug in air and enable 1CR IIRC to enable the rest of the SSR's.... you will need the 24vdc power supply on. If you have a short on the 24v buss the first place to look is the turret encoder.
Do you have a wiring diagram for your CHNC?
13 Jul 2012 20:23 #21921
by bobinater
Yes on the huge control cabinet, However I do not get any response when I turn the main power on at the
large enclosure that I would call the power in section. it has the main circuit disconnect and it is located at the tailstock end of the lathe
It is an HNC not CHNC. when I turn the power on at the controll I still get no response. What does IIRC stand for (if I recall correctly?)
I don't want to sound stupid but I am not very good at acronyms for electronics, so what are SSR's as well. when I plug in shop air to the connector I have
a hard core leak from the air solenoid cabinet on the lower front of the lathe, still have not been able to isolate this leak, will get back on it this weekend
Bob
Bob
13 Jul 2012 20:26 #21922
by bobinater
I do have the wiring diagram for the HNC but it is all in acronyms so untill i learn what they are I am in deep
I do have extensive experience at reading electrical diagrams for automobiles but its been awhile since I really dug into
anything this complex.
BOB
BOB
Moderators: cncbasher
Time to create page: 0.155 seconds
