Light Machine Corp. Benchman XTr (retrofit)
- Thank you received: 5935
17 Jan 2017 19:22 #85982
To big files, most probably, just use GIMP or any other software that can downscale them.
Replied by tommylight on topic Light Machine Corp. Benchman XTr (retrofit)
having trouble uploading the other JPGs for some reason
17 Jan 2017 19:28 #85984
by TGTROPIC
Replied by TGTROPIC on topic Light Machine Corp. Benchman XTr (retrofit)
even compressed gets same error message " File Upload Failed"
17 Jan 2017 20:17 #85991
by TGTROPIC
Still no luck..have compressed, zipped and and still unable to upload. first file was JPG so no problem with type and sizes under limits. Problem with Forum? Don't mean to Hijack BTW.
17 Jan 2017 20:25 #85995
Just uploaded some pics and a pdf file, some 20 minutes ago, no problems.
Try it from the phone or tablet if you can.
18 Jan 2017 02:57 - 18 Jan 2017 02:58 #86027
I use Photobucket for all my forum photos and insert with the IMG command
Photobucket has a link that contains the right format for each photo and you just need to paste into the thread
Replied by rodw on topic Light Machine Corp. Benchman XTr (retrofit)
Last edit: 18 Jan 2017 02:58 by rodw.
The following user(s) said Thank You: TGTROPIC
- dynamyte24
18 Jan 2017 05:28 #86032
by dynamyte24
Thanx for that info, Don.
I'd like to run my Benchman without the 4th, but I get an Error (4th axis encoder open) IIRC.
I have unchecked "Rotary Axis" in the Benchman Setup panel (pg E-66), but the error persists.
Is there something else I need to do?
Rex
Replied by dynamyte24 on topic Light Machine Corp. Benchman XTr (retrofit)
Machines could be configured and built for the fourth axis, but not shipped with the 4th axis due to budget constraints and the 4th axis was purchased at a later time.
Rex
- x-Intelitek Engineer
- Thank you received: 22
18 Jan 2017 15:00 #86054
by x-Intelitek Engineer
Replied by x-Intelitek Engineer on topic Light Machine Corp. Benchman XTr (retrofit)
Rex,
In order to run a 4th axis ready machine without the 4th axis, there is a jumper plug that must be plugged into the connector on the back wall of the machine. I will have to look-up and find that information for you. I will see if I can find it later today.
Don
Don
18 Jan 2017 17:21 #86067
Rex,
That jumper plug is Intelitek P/N 32-5400-0386 and it is in-stock and available for $40.92 according to Intelitek's tech support. Let me know if that is what you need.
Don
Don
The following user(s) said Thank You: dynamyte24
18 Jan 2017 17:36 #86070
I got your photos through e-mail and I know where your machine stands. I need to know your comfort level with a DVM and your access to jumper leads (wires with clips (either spring or alligator) at each end).
Moderators: cncbasher
Time to create page: 0.158 seconds
