Hardinge HC Bandit Retrofit
09 Dec 2017 19:49 #102839
by mclausen
Replied by mclausen on topic Hardinge HC Bandit Retrofit
The resolvers are belt driven off of the motor.
Here is the section of my Hal file:
Is this trying to drive by position?
net x-index-enable <=> pid.x.index-enable
net x-enable joint.0.amp-enable-out => pid.x.enable
net x-pos-cmd joint.0.motor-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-enable => hm2_5i24.0.pwmgen.00.enable
net x-output pid.x.output => hm2_5i24.0.pwmgen.00.value
setp hm2_5i24.0.pwmgen.00.scale [JOINT_0]OUTPUT_SCALE
# ---Resolver feedback signals/setup---
setp hm2_5i24.0.resolver.excitation-khz 5
setp hm2_5i24.0.resolver.00.scale [JOINT_0]RESOLVER_SCALE
net x-pos-fb hm2_5i24.0.resolver.00.position => joint.0.motor-pos-fb
net x-vel-fb <= hm2_5i24.0.resolver.00.velocity
net x-index-enable joint.0.index-enable <=> hm2_5i24.0.resolver.00.index-enable
09 Dec 2017 19:54 #102840
Replied by andypugh on topic Hardinge HC Bandit Retrofit
I don't see anything setting the PID gains in that HAL snippet.
09 Dec 2017 19:57 #102841
by mclausen
# AXIS X
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror 1
# AXIS X
09 Dec 2017 19:58 - 09 Dec 2017 19:58 #102842
Replied by PCW on topic Hardinge HC Bandit Retrofit
Yes that's a position mode loop and looks OK
Crazy behaviour in one direction suggests that the PWM mode is not set correctly
The 7I48 and 7I49 require that the PWM mode be up/down (output_type = 2)
Last edit: 09 Dec 2017 19:58 by PCW.
09 Dec 2017 19:58 #102843
by mclausen
Andy,
I started with a copy of your Holbrook files and modified them.
09 Dec 2017 20:01 #102844
I think that PCW has spotted the problem, we have seen this before.
Set the output_type and then start adjusting P, I and D until it works properly.
There is no specific setting for the control mode of the system, but if you know what it is it can give you some ideas what the PID tuning is likely to look like. But you nearly always start with P-gain.
09 Dec 2017 20:08 - 09 Dec 2017 20:10 #102845
by mclausen
Currently there is no call out for PWM.
Should I just add loadrt pwmgen output_type=2?
Or do I change this line : loadrt hm2_pci config="num_encoders=2 num_pwmgens=2 num_resolvers=2"
Last edit: 09 Dec 2017 20:10 by mclausen.
09 Dec 2017 20:22 - 09 Dec 2017 20:23 #102846
No, you set the mode of the existing hardware pwmgens like this:
setp hm2_5i24.0.pwmgen.00.output-type 2
setp hm2_5i24.0.pwmgen.01.output-type 2
(man hostmot2)
also
halcmd show all
to get a list of all available pins and parameters
(man hostmot2)
also
halcmd show all
Last edit: 09 Dec 2017 20:23 by PCW. Reason: change set to setp
09 Dec 2017 21:00 #102848
by mclausen
Success! The x axis now moves smooth in both directions. I did have to change the OUTPUT_SCALE to positive. It was negative to match the direction before.
Speaking of OUTPUT_SCALE, what should this be set at?
09 Dec 2017 21:02 #102849
Whatever works
Normally you would scale it to 10V but to be honest it can be in any units at all, you just end up with different PID gains to compensate.
Whatever works
Moderators: cncbasher
Time to create page: 0.233 seconds
