Brother TC-225 / TC-229 adventure!
20 Aug 2017 22:55 #97800
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
Its been a while since i did this, but I think you are close.
Some named parameters exist without the prolog code, look in the G-code parameters docs.
- ihavenofish
- Thank you received: 83
21 Aug 2017 04:00 #97805
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
Ok m6 tx working perfect. Adding on z motion now.
How do I move the z soft limit on the fly?
I can't find the reference I saw before. On my phone in front of the machine googling. Haha.
- ihavenofish
21 Aug 2017 16:07 #97824
by ihavenofish
while were on the swapping limits... swapping to servo spindle mode or the equivelant for orienting...
ive looked at the drawing, it makes sense I think, but how do I implement it?
Linuxcnc wont let me assign 2 axes to one output, so clearly that's not the way its done
thanks
thanks
22 Aug 2017 10:18 #97864
I can't find which module they are documented in either. But I imagine you would use these pins:
Component Pins:
Owner Type Dir Value Name
65 float IN 0 ini.0.backlash
65 float IN 0.05 ini.0.ferror
65 float IN 0 ini.0.home
65 float IN 0 ini.0.home_offset
65 s32 IN 1 ini.0.home_sequence
65 float IN 50 ini.0.max_acceleration
65 float IN 40 ini.0.max_limit
65 float IN 5 ini.0.max_velocity
65 float IN 0.01 ini.0.min_ferror
65 float IN -40 ini.0.min_limit
65 float IN 0 ini.1.backlash
65 float IN 0.05 ini.1.ferror
65 float IN 0 ini.1.home
65 float IN 0 ini.1.home_offset
65 s32 IN 1 ini.1.home_sequence
65 float IN 50 ini.1.max_acceleration
65 float IN 40 ini.1.max_limit
65 float IN 5 ini.1.max_velocity
65 float IN 0.01 ini.1.min_ferror
65 float IN -40 ini.1.min_limit
65 float IN 0 ini.2.backlash
65 float IN 0.05 ini.2.ferror
65 float IN 0 ini.2.home
65 float IN 1 ini.2.home_offset
65 s32 IN 0 ini.2.home_sequence
65 float IN 50 ini.2.max_acceleration
65 float IN 0.12 ini.2.max_limit
65 float IN 5 ini.2.max_velocity
65 float IN 0.01 ini.2.min_ferror
65 float IN -8 ini.2.min_limit
65 float IN 0 ini.a.max_acceleration
65 float IN 0 ini.a.max_limit
65 float IN 0 ini.a.max_velocity
65 float IN 0 ini.a.min_limit
65 float IN 0 ini.b.max_acceleration
65 float IN 0 ini.b.max_limit
65 float IN 0 ini.b.max_velocity
65 float IN 0 ini.b.min_limit
65 float IN 0 ini.c.max_acceleration
65 float IN 0 ini.c.max_limit
65 float IN 0 ini.c.max_velocity
65 float IN 0 ini.c.min_limit
65 bit IN TRUE ini.traj_arc_blend_enable
65 bit IN FALSE ini.traj_arc_blend_fallback_enable
65 float IN 4 ini.traj_arc_blend_gap_cycles
65 s32 IN 50 ini.traj_arc_blend_optimization_depth
65 float IN 100 ini.traj_arc_blend_ramp_freq
65 float IN 0.1 ini.traj_arc_blend_tangent_kink_ratio
65 float IN 1e+99 ini.traj_default_acceleration
65 float IN 5 ini.traj_default_velocity
65 float IN 1e+99 ini.traj_max_acceleration
65 float IN 5 ini.traj_max_velocity
65 float IN 0 ini.u.max_acceleration
65 float IN 0 ini.u.max_limit
65 float IN 0 ini.u.max_velocity
65 float IN 0 ini.u.min_limit
65 float IN 0 ini.v.max_acceleration
65 float IN 0 ini.v.max_limit
65 float IN 0 ini.v.max_velocity
65 float IN 0 ini.v.min_limit
65 float IN 0 ini.w.max_acceleration
65 float IN 0 ini.w.max_limit
65 float IN 0 ini.w.max_velocity
65 float IN 0 ini.w.min_limit
65 float IN 50 ini.x.max_acceleration
65 float IN 40 ini.x.max_limit
65 float IN 5 ini.x.max_velocity
65 float IN -40 ini.x.min_limit
65 float IN 50 ini.y.max_acceleration
65 float IN 40 ini.y.max_limit
65 float IN 5 ini.y.max_velocity
65 float IN -40 ini.y.min_limit
65 float IN 50 ini.z.max_acceleration
65 float IN 0.12 ini.z.max_limit
65 float IN 5 ini.z.max_velocity
65 float IN -8 ini.z.min_limit
- ihavenofish
22 Aug 2017 11:45 #97865
by ihavenofish
O_o
now I'm just more confused, haha.
so,
ini.2.max_limit would be our z axis upper soft limit which we could change on the fly from the toolchange subroutine?
ini.z.max_limit is also there. odd.
so,
- ihavenofish
22 Aug 2017 12:04 #97867
by ihavenofish
while were at limits... when I home the machine, randomly, on any axis, it will occasionally give an f error. the machine is finding the switch, then the index. it always give the error when hitting the index.
any thoughts? at the speed its running, I cant see how it would be exceeding the f error, especially since it never does at any other speed.
22 Aug 2017 13:39 #97872
Replied by PCW on topic Brother TC-225 / TC-229 adventure!
is the per axis index_enable signal wired to the PID component?
If not this can cause a thump when index is detected
Also I've seen this when the thread order is wrong. Handling index detection is a bit tricky since the position
is zeroed when index _enable is true and the index is detected.
- ihavenofish
22 Aug 2017 14:30 #97876
by ihavenofish
all I did was check use index in pncconf wizard. ill have to check the hal/ini to see what its actually done. there definitely seems to be a thump though.
- ihavenofish
23 Aug 2017 00:27 #97900
by ihavenofish
Ok on the homing.
After setp stuff the next line is about using index.
Net x-index-enable <=> pid.x.index-enable
Should this move?
Should this move?
- ihavenofish
23 Aug 2017 00:30 #97901
by ihavenofish
Now how am I dealing with the z limit. I don't see the pins andy wrote in there already. Where would I ad it and how do I use it? Thanks.
Moderators: cncbasher
Time to create page: 0.117 seconds
