Brother TC-225 / TC-229 adventure!
- ihavenofish
- Thank you received: 83
25 Aug 2017 17:44 #98010
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
heres the stock control video again. you can see that the axes are very smooth, especially during acceleration. no thump... so, we know it can be done
25 Aug 2017 17:54 #98013
Replied by PCW on topic Brother TC-225 / TC-229 adventure!
Can you provide a screenshot of the following error (and the velocity) to determine
if this is really a tuning issue or something wrong/suboptimal in the trajectory planner setup
- ihavenofish
25 Aug 2017 18:03 #98014
by ihavenofish
ok, I will see if I can do a video showing the halscope for the y and the z (the worst offenders) while its running.
ill take some screen grabs as well, although I was having trouble with doing that. video might prove more useful.
note that this is also in just straight line jogging, not just that program.
which parameters would you like to see? ive been looking at f error, as well as the actual analogue output on the mesa card. they seem to have been giving the most clues to me.
thanks.
thanks.
- ihavenofish
25 Aug 2017 18:03 #98015
by ihavenofish
25 Aug 2017 18:06 #98016
basically, no
For velocity mode servos, 99% of the tuning is in the drive (and having FF1 set properly in LinuxCNC)
AT-PID will just make a mess of this
- ihavenofish
25 Aug 2017 18:07 #98017
by ihavenofish
ah ok. too bad, haha.
- Thank you received: 1369
25 Aug 2017 18:26 #98018
No need to mess with videoing anything, just a simple screen shot of the halscope screen when making a short jog (20mm or so).
To take a screen shot, from the main desktop menu select Accessories/Screenshot.)
like this
Replied by Todd Zuercher on topic Brother TC-225 / TC-229 adventure!
like this
- ihavenofish
25 Aug 2017 18:31 #98019
by ihavenofish
my trouble is figuring out how to make the halscope stop and show a move like that
how does it know where to record from and to?
25 Aug 2017 18:40 #98020
ok so one _really_ basic thing: These are torque mode drives NOT velocity mode so tuning is quite different
25 Aug 2017 18:41 #98021
From the trigger source. When the value of the trigger source crosses the trigger level (in the chosen direction (rising or falling) Halscope starts recording the sample.
In the above, I was using channel 3 (axis.0.joint-vel-cmd) as the trigger source, and the green dotted horizontal line in the Halscope plot was the trigger level.
Moderators: cncbasher
Time to create page: 0.219 seconds
