Brother TC-225 / TC-229 adventure!
- ihavenofish
- Thank you received: 83
22 Feb 2017 12:34 #88492
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
not sure a 24v 50w drive will cut it
but yeah, im scouring ebay. these motors are a bit non standard and have zero documentation to be found, so its not easy to know which will work. the spindle is the main challenge.
23 Feb 2017 13:10 #88537
Probably not. I was more linking to the specific vendor.
There seem to be a lot of used servos and drives coming out of Thailand too.
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
- ihavenofish
23 Feb 2017 15:41 #88544
by ihavenofish
yeah, lots of stuff, but the prices arent as good as they used to be im finding. barely cheaper than brand new delta stuff.
- ihavenofish
23 Feb 2017 18:01 #88550
by ihavenofish
tc 225 alive! woot. thats the analogue machine.
for the other one, i can get shiny new delta 750w ac servos for the x and y for about $600us each. thats a start.
gotta find a suitable 1kw z with brake now.
The following user(s) said Thank You: Assauri
- Thank you received: 5934
23 Feb 2017 18:08 #88551
Replied by tommylight on topic Brother TC-225 / TC-229 adventure!
Oh goodie goodie goodie!
Nice job.
Nice job.
- ihavenofish
23 Feb 2017 18:45 #88552
by ihavenofish
well, all i did was plug it in. haha.
- ihavenofish
24 Feb 2017 23:33 - 24 Feb 2017 23:34 #88607
by ihavenofish
ok, for the tc229, im looking at new delta asd-a2 drives and matching motors - 750w x/y, 1kw z, and then a delta c2000 5.5kw drive to run my spindle. the c2000 is a vfd that can run ac servos with encoders. all of these will take +- 10v input.
i looked at a lot of options for reusing the existing axis servos, but the cost difference to a new delta setup was negligible.
someone i know is using allen bradley ultra 3000 drives with the stock motors, which can be had used fairly cheap, but they seem to have a very slow velocity loop of 300hz (vs 1khz+ for newer systems) which makes me think it wont give good high speed tracking.
anyone have any thoughts on this? ive only ever run step and direction before on comparatively slow machines.
Last edit: 24 Feb 2017 23:34 by ihavenofish.
- ihavenofish
26 Feb 2017 19:26 #88641
by ihavenofish
i found some sanyo sanmotion R analogue input drives for $300 us a piece with free shipping. looking at the manual, they should be compatible with the older sanyo motors. i can enter in the correct encoder count. sooo, we'll see early next week. they should arrive tuesday maybe.
if they work, ill order the delta spindle drive and off we go converting to linux
- ihavenofish
27 Feb 2017 19:15 #88699
by ihavenofish
hmm. so these drives take a motor profile, which is 53 parameters but they are in hex format.
they have profiles for P5 series motors - 1 model newer than mine (still 90's). in the p5 literature it says p5 is a compatible replacement for mine (65z), and some of the drive instruction manuals meant for the p5 series suggest being compatible with the 65z, though i cant fine motor profile files for them. so i am going to use the motor profile for the p5 model that matches mine. same frame, same speed, same torque.
ill measure the resistance one mine and compare to the p5 specs. if they match, or they are very close, i imagine it should work no?
28 Feb 2017 16:49 #88746
[quote="ihavenofish" post=88699ill measure the resistance one mine and compare to the p5 specs. if they match, or they are very close, i imagine it should work no?[/quote]
It should be close enough to work at least. I guess very-wrong numbers might lead to problems tuning.
Moderators: cncbasher
Time to create page: 0.114 seconds
