Brother TC-225 / TC-229 adventure!
- ihavenofish
- Thank you received: 83
31 Jul 2017 02:45 #96715
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
hmm, I see the first half of that is easy enough, haha. (I'm at home now, so no machine in front of me, just reading the docs). just tie that button (axis.0.amp-enable-out) to an output to that relay.
so its more now attaching the brake release to that, timed a few seconds afterward.
31 Jul 2017 03:46 - 31 Jul 2017 03:46 #96718
Replied by rodw on topic Brother TC-225 / TC-229 adventure!
This was discussed on another thread in the last couple of days.
forum.linuxcnc.org/39-pncconf/33069-help...i73-on-my-mill-going
Use the machine-on signal to turm on your main relay.
Then send machine-on to a timedelay component to enable your brake. Easy!
timedelay has an on delay and an off delay pin so you can decide when to trigger it when you turn it off. Probably with a time off delay of 0.
Last edit: 31 Jul 2017 03:46 by rodw.
- ihavenofish
31 Jul 2017 04:08 #96719
by ihavenofish
cool thanks!
ill read through that.
31 Jul 2017 09:25 #96733
Do you want it to be a few seconds later every time? Is there an Amp-ready signal from the Z-axis drive that could be used instead? That seems like it might be a better way.
a time-delay on a HAL signal is very easy, though.
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
- ihavenofish
31 Jul 2017 11:28 #96749
by ihavenofish
well, when the normal control starts up... the brake disengages a second or so after the power engages. it seems not to be relying on feedback from the amp (because it does it even with the amps control cable disconnected.
the only feedback from the amp besides encoder we get is an alarm which I think only goes high for an error.
so I'm not sure if there is a "smart" way to release the brake here.
31 Jul 2017 11:55 #96754
Connecting the brake to the alarm sounds like a good idea to me.
Does the alarm go off after amp-enable, or is it always off?
Have you worked out how to use the timedelay HAL function?
- ihavenofish
31 Jul 2017 12:13 #96756
by ihavenofish
I'm at work so ill figure that out tonight.
the alarm - hmmmmm. that's one scenario didn't look at. I bet it does. that would make it pretty sensible, as the drives are powered on their control side when the machine starts - before the main power is engages, so it stands to reason they would alarm until they have full power.
thanks
thanks
- ihavenofish
01 Aug 2017 03:31 #96805
by ihavenofish
So first roadblock.
Error could not insert module.... invalid parameters.
Down at the bottom... config num encoders 6 but only 2 available.
What did I do wrong?
- ihavenofish
01 Aug 2017 03:58 #96806
by ihavenofish
Nevermind. I have the 7i76 firmware on it Dr. My router. Bahhhhhh
01 Aug 2017 09:51 #96815
Have you solved this now?
Moderators: cncbasher
Time to create page: 0.540 seconds
