which card to buy
21 Apr 2017 13:56 #91786
by Jorgefv
which card to buy was created by Jorgefv
Hi I want to retrofit a Weeke BP 10
the controller is dead but everything else seems to be OK, I run into the mesa cards and I think that would be ideal for that machine but I'm really confused on what cards to buy
I want to get it working, it uses the intramat analog servos and has lots of pneumatic actuators, it also has an analog input vfd that seems to be working very well
I have never used this card nor made a cnc retrofit before my only experience with cnc is making small machines with steper motors and the parallel port of an old pc with mach 3
I was thinking on the
6I24-25
7I48
and for the IO
7I44
7I70
7I71/7I72
are this the right choice? do I need something less something more?
6I24-25
7I48
and for the IO
7I44
7I70
7I71/7I72
21 Apr 2017 14:10 #91787
Replied by PCW on topic which card to buy
A more common choice of Mesa cards would be a 5I25/6I25 (PCI/PCIE)
and a 7I77 + 7I74
then whatever sserial daughter cards are needed
and a 7I77 + 7I74
The following user(s) said Thank You: Jorgefv
22 Apr 2017 16:32 #91855
by Jorgefv
Replied by Jorgefv on topic which card to buy
I have been reading the forum for a while and I noticed that the 5i25 + 7i77 is the mot common solution
I wanted to use the 6i24 because that is the one that seems more flexible and I want to make my custom daughter cards in the future, I have worked with fpga designs in the past.
the thing I don't know very well is Linux and how to get a cnc working with this cards so I want to know that the cards I chosed before would work for retrofitting the Weeke BP 10
in performance an scalability an things like that maybe is better or worse I don't know but I am not afraid to get the hands dirty and learn.
the only thing is that I don't want to forget to buy something maybe some cables or adapters thing that are not that obvious, because shipping and taxes to my country is very expensive and is better to get more at once.
24 Apr 2017 15:49 #91972
by Jorgefv
I might go ahead and buy the cards I hope I'm not doing anything dumb.
25 Apr 2017 16:31 #92074
Replied by andypugh on topic which card to buy
I am using the 6i24 on my lathe, and I am happy with it.
You will need 50-way ribbon cable and the matching connectors,but you should be able to get that locally.
22 May 2017 20:51 #93508
by TSEGEO
Replied by TSEGEO on topic which card to buy
Look at lonnox.de on the site it is a very detailed guide for mesa cards. They have already retrofit one the same machine . Look at youtube lavalucnc.
I do the same with my cnc and there is a very helpful address.
22 Jun 2017 14:22 #94786
by Jorgefv
I bought and received the 6i24 plus the other cards, really fast shipping compared to other things I bought from other countries.
now I have installed linuxcnc on a new machine thanks to the excellent tutorial from cncnoob1979.
now I'm stuck on what to do next I have downloaded the software from the 6i24 page which happens to be the same that te 5i24 uses I'm currently reading to know what to do next, I think I do not have the hostmot2 drivers installed
22 Jun 2017 14:37 #94787
The hostmot2 driver is part of LinuxCNC, so if you have LinuxCNC installed, you have the driver installed
22 Jun 2017 14:38 - 22 Jun 2017 14:38 #94788
The drivers are part of LinuxCNC.
Here is a quick (command line) way to tell if the cards are working.
If you see a list of HAL pins, then it is working.
halrun
loadrt hostmot2
loadrt hm2_pci
show pin
Last edit: 22 Jun 2017 14:38 by andypugh.
22 Jun 2017 15:25 #94790
by Jorgefv
the command worked and discovered the 6i24 as a 5i24 just as expected I just got confused because while opening the PncconfWizard I got the message "you have no hostmot2 firmware downloaded in folder /lib/firmware/hm2/ PNCconf will use internal firmware data" now I'm a bit lost but I will try to get it working I have got the 6i24, 7i48, 7i44, 7i70, 7i71, 7i73
Moderators: cncbasher
Time to create page: 0.136 seconds
