Retrofit Leadwell MCV 600XL
22 Sep 2019 19:01 - 22 Sep 2019 19:01 #145882
by danilom
Retrofit Leadwell MCV 600XL was created by danilom
Last edit: 22 Sep 2019 19:01 by danilom.
22 Sep 2019 22:40 - 22 Sep 2019 22:40 #145895
by bevins
Why you changing the Fanuc redcaps. I think I read a while ago they can be used.
That looks like a fun project....
Replied by bevins on topic Retrofit Leadwell MCV 600XL
After accidentally crashing the spindle orientation sensor and having extra 2kw china servos its time to be out with the old in with the new.
As fanuc motors had tapered axis first thing is to make new holes on ballscrew couplers, then proceed to wiring
Last edit: 22 Sep 2019 22:40 by bevins.
23 Sep 2019 07:02 #145924
by pl7i92
Replied by pl7i92 on topic Retrofit Leadwell MCV 600XL
did the Z axis Bend on a crash you shoudt hardly check the Axis moving
as offen on this mashines the PTFE line bends break there are made for this event to take the Hardest and be replaced
24 Sep 2019 21:24 #146108
by danilom
Replied by danilom on topic Retrofit Leadwell MCV 600XL
I have no time to play with red caps, maybe sometime , one company from Vietnam makes fanuc compatible drives.
pl7i92 - It was not a physical crash , while removing the spindle cartridge for bearing change I broke the sensor ( fsh 1378 price around 1000usd )
24 Sep 2019 21:26 #146109
by bevins
What did you pay for the 2KW servo's? and drives? If you dont mind me asking.
24 Sep 2019 22:21 #146110
by danilom
I ordered them from one company in Bulgaria this is link to their shop
Vallder
- Thank you received: 5972
24 Sep 2019 23:20 #146116
Serbian:
Da li moras da placas porez za stvari iz Bugarske ? Koliko kosta postarina i koliko traje prevoz ?
Regards,
Tom.
Replied by tommylight on topic Retrofit Leadwell MCV 600XL
Do you have to pay taxes for stuff from Bulgaria ? How much is the delivery and how long does it take ?I ordered them from one company in Bulgaria this is link to their shop Vallder
Serbian:
Regards,
Tom.
26 Sep 2019 15:59 - 26 Sep 2019 16:00 #146277
by danilom
They have a local distributor in Serbia, because owner is from here so items get delivered directly, Prices are without VAT.
After careful measuring it seems that Y drive has short cables, also originally cables have been inside protective hose and because of connectors on encoder cable it will be impossible to pull them trough. So I will reuse the original cables , lots of soldering but less complicated than to pull trough all new cables.
Last edit: 26 Sep 2019 16:00 by danilom.
27 Sep 2019 00:52 #146307
Thank you.
Hvala.
Web? Address? Phone no?They have a local distributor in Serbia, because owner is from here so items get delivered directly, Prices are without VAT.
Thank you.
Hvala.
27 Sep 2019 05:54 #146329
by danilom
The following user(s) said Thank You: tommylight, Clive S
Moderators: cncbasher
