- Hardware & Machines
- CNC Machines
- How do i pick up the correct circuit breaker and protective fuse for my VFD?
- blackmennewstyle
- Topic Author
11 Apr 2020 12:59 - 11 Apr 2020 12:59 #163603
by blackmennewstyle
How do i pick up the correct circuit breaker and protective fuse for my VFD? was created by blackmennewstyle
Hello,
I did not know where to post that question so i hope i am at the correct section.
But i would like to know how do i pick up the correct circuit breaker and protective fuse for my VFD frequency inverter?
I'm planing to use an Huanyang VFD huanyang 1.5KW 220V VFD frequency inverter (model: HY01D523B) with a 1.5KW (1HP=0.735KW) 220V 7A spindle.
The user-manual of the VFD actually only recommends to use a non fuse circuit breaker between the power supply and the VFD. But i would like to use a circuit breaker and a fuse between the power supply and the VFD. So what are the calculations involved to determine and pick up the right circuit breaker and fuse for the job?
My plan is to learn so feel free to provide educative answers if necessary. Thanks in advance
Last edit: 11 Apr 2020 12:59 by blackmennewstyle.
- Thank you received: 5946
11 Apr 2020 13:38 #163609
Replied by tommylight on topic How do i pick up the correct circuit breaker and protective fuse for my VFD?
Check the manual, it should have the max current it can draw on the input and get the next bigger value for the circuit breaker. No fuse, it does not make sense having both doing the same job.
Example, VFD current draw 12A, get a 16A circuit breaker.
- blackmennewstyle
- Topic Author
11 Apr 2020 13:59 #163614
by blackmennewstyle
Thank you again for your answer. Well, i guess sometimes there is no need to overthink.
Have a great weekend
Replied by blackmennewstyle on topic How do i pick up the correct circuit breaker and protective fuse for my VFD?
11 Apr 2020 21:01 #163655
Thank you, you too.
26 Feb 2024 16:00 #294533
Spammer booted.
Moderators: cncbasher
- CNC Machines
Time to create page: 0.167 seconds
