- Hardware & Machines
- CNC Machines
- A retrofit of a Stanko SMO 32 CNC milling machine (Ukrainian clone of a Maho)
Now I'm confused. There is a connection and then the connection is closed?I unscrewed the top of the device to uncover contacts and there is a connection between the contacts when the machine is off. But then as soon as the voltage comes in the connection is closed
[edit]
I think you might want to open the hydraulic line to make sure there is indeed no pressure in the system.
Good idea with opening the line, I’ll try that. That said, I’m not sure why would it work like that - if there’s pressure in the system the contacts should be disconnected even without voltage I think
Remove the cable from the pressure switch and check resistance across the connections with the machine off and with the machine on. If the contact changes then there must be something going on with the pressure in line. If it's open both times then there is either pressure in the line or the switch is broken.
Thanks for the suggestions!
I think that the pump and the pressure switch might be fine after all.
As @Aciera suggested I unscrewed the switch to remove any pressure from the pump. At this point contacts were conducting with zero resistance. Then I figured I will do a dirty test, ie. I turned the machine on and pressed the "hydraulics on" button for a split second and I got a nice splash of oil on the enclosure opposite to where the pressure switch is
That would suggest that the pump works. I screwed the pressure switch back in and measured the contacts and again, it was conducting. I turned the machine on, I turned the hydraulics on. I didn't hear the pump, but when I measured the contacts there was no connection there, which made me think that either the pressure is built very quickly or that the switch is broken. I put the camera in my phone into recording mode and I pressed the hydraulics to capture the moment when it turns on. Lo and behold, I present to you the quick action pump:
I think that with the valves closed it just doesn't need much to pressurize the line.
In summary the hydraulic pump might be alright and what affects the system are still the outputs from the CNC controller that keep the rest of the system from turning on. I think that this might have been also the issue when I first got the machine - it was booting to a further place, but tool clamping didn't work, so I think that the solenoid valve 5Y1 wasn't able to turn on because of some issue with the system.
The conclusion is that I guess I'll get to the retrofit sooner than I initially thought, which honestly might be for the better. Otherwise, even if I made the machine work with Heidenhain, I would have to learn how to use Heidenhain only to replace it in the future. I'm going to order all of the components this weekend.
1. The Heidenhain EXE modules, which are used to translate analog signal into digital, are mounted directly in the LE 360 CNC controller. I don't want to keep it, cause it takes a lot of space and I can probably sell it for good money, so I figured it will be better to buy standalone EXE modules. Thus I ordered 3 Heidenhain 602D modules. They offer 1x or 5x interpolation and I don't need a resolution lower than a micron, so it should be good enough.
2. I was wondering how many inputs and outputs do I need. I think that 32 inputs and 16 outputs will be enough given that the original controller uses less I/O. I'm not 100% sure about the gear change, but I decided to go with two boards for now: 6i25 and 7i77. If I want to have more I/O then I will add a 7i84D board, but hopefully that won't be needed.
3. I'm not sure how to do a gear change yet. I've seen that RotarySMP used HAL ladders for that, but I'm a computer programmer with like a dozen languages that I used throughout my career, so I feel like I'd prefer to handle that directly in code. Still not sure how it works for LinuxCNC, but I'm curious to play with it when the boards come
4. I don't really like the wiring situation in the cabinet. In the Maho it's definitely done in a neater way and I'm thinking that maybe I'll design and order a custom PCB to clean it up a bit. Like a thing sitting between Mesa boards and the breakout board for the 24V contactors. But first I want to connect it as is so that I can verify all the functions.
I think that the best plan will be to go with various inputs and outputs of the current CNC controller and swap them with the new controller, cause everything needed for the machine to work should be included in there.
I've changed the subject to mention "Ukrainian clone of a Maho". I originally wrote Russian, but that's because "Stanko" or "Stankoimport" are associated with Russian machines, but the fact is that this name was stamped on most of the stuff coming from the east. And a few days ago it struck me that the documentation I say actually mentions Ukraine, not Russia as an origin of the machine and also another name for those machines was Odessa SMO 32. I know that it doesn't change much, but I figured that especially in the light of current events I should get the origin of the machine right.
- Thank you received: 5972
It's just that since I realized this and after the start of invasion I just couldn't let it sit like this. Again, I know changes nothing, but it just didn't feel right, especially now.
- CNC Machines
