Mini wannabe datron build
29 Apr 2023 07:43 #270169
Replied by rodw on topic Mini wannabe datron build
Sounds like you did not tick a gui when you installed. See my instructions 9-10
docs.google.com/document/d/1jeV_4VKzVmOI.../edit?usp=share_link
There is a fairly easy fix
Select XFCE and install it, reboot into a gui
sudo apt install tasksel
sudo tasksel
- ihavenofish
- Thank you received: 84
29 Apr 2023 07:54 #270170
by ihavenofish
Replied by ihavenofish on topic Mini wannabe datron build
I think part of the issue is my network doesnt work during the install.
sudo "command not found"
hmm
hmm
29 Apr 2023 08:12 #270172
Somehow get network for the install as the image I shared is a network install, just the minimum.
- ihavenofish
29 Apr 2023 08:44 #270175
by ihavenofish
Yes, it was network. didnt respect my wifi card or something. i swapped to the network the mesa card was one and it all went fine.
thanks
now to install linuxcnc...
thanks
- ihavenofish
29 Apr 2023 09:26 - 29 Apr 2023 09:27 #270178
by ihavenofish
linuxcnc installed, starting on probe basic based on instructions... got this error
dpkg: warning: 'ldconfig' not found in PATH or not executable
dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
dpkg: error: 2 expected programs not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
Last edit: 29 Apr 2023 09:27 by ihavenofish.
- ihavenofish
29 Apr 2023 09:44 #270179
by ihavenofish
oook, next error.
cp: cannot create regular file '/home/root//Pictures/': Not a directory
dpkg: error processing package python3-probe-basic (--install):
installed python3-probe-basic package post-installation script subprocess returned error exit status 1
Processing triggers for fontconfig (2.14.1-4) ...
Errors were encountered while processing:
python3-probe-basic
python3-probe-basic
- ihavenofish
29 Apr 2023 10:18 #270182
by ihavenofish
ok, seems to be installed, but it errors if i try to open linuxcnc with the probe basic ui. it also does not provide me with that as an option in pncconf.
- ihavenofish
29 Apr 2023 10:25 #270183
by ihavenofish
so this is the error starting up.
[qtpyvcp.widgets.display_widgets.vtk_backplot.vtk_backplot][[37mDEBUG[0m]
translate1: (0.0, 0.0, 0.0) (vtk_backplot.py:142)
active_wcs_offset: (0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0) (vtk_backplot.py:143)
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 12 (X_ConfigureWindow)
Resource id in failed request: 0x5
Serial number of failed request: 7
Current serial number in output stream: 8
24575
24612
Stopping realtime threads
Unloading hal components
Note: Using POSIX non-realtime
24575
24612
- Thank you received: 5988
29 Apr 2023 10:37 #270184
Get the new ISO, with GUI, while installing if it asks for a root password, do not enter anything, just move on, it will ask for a new user name and password.
Replied by tommylight on topic Mini wannabe datron build
Means you are running as ROOT, not a user, so some stuff will not work properly, pretty sure LinuxCNC also does not run as root.
- ihavenofish
29 Apr 2023 10:47 - 29 Apr 2023 10:52 #270186
by ihavenofish
you are about 12 posts late . we are well past that, now im trying to figure out why probe basic isnt starting.
Last edit: 29 Apr 2023 10:52 by ihavenofish.
Moderators: cncbasher
Time to create page: 0.154 seconds
