Mini wannabe datron build
29 Apr 2023 11:02 #270188
Replied by rodw on topic Mini wannabe datron build
The installation method has changed for QTPYVCP and ProbeĀ BAsic. Refer to the relevant forum section here for how tosyou are about 12 posts late . we are well past that, now im trying to figure out why probe basic isnt starting.
- ihavenofish
- Thank you received: 84
29 Apr 2023 11:04 #270189
by ihavenofish
Replied by ihavenofish on topic Mini wannabe datron build
hi, that is what i followed, the latest instructions on the google drive with the 3 files.
or is there something even newer?
- Thank you received: 5979
29 Apr 2023 11:08 #270190
Replied by tommylight on topic Mini wannabe datron build
6you are about 12 posts late . we are well past that, now im trying to figure out why probe basic isnt starting.
29 Apr 2023 11:10 #270191
The errors refer to VTK, not sure but that should be Vulkan drivers.
No real time kernel.Note: Using POSIX non-realtime
- ihavenofish
29 Apr 2023 11:12 #270192
by ihavenofish
hmm
so this is something that should have been installed with linux, before i got to linuxcnc?
this is why i always pick the release versions, i really have no clue what to do with linux haha.
29 Apr 2023 11:29 #270193
Take Rod's advice and his howto, even i switched to BookWorm from using Mint on everything.
Although since you need ProbeBasic ( i really, really wish someone somehow would name it something else as there is a probe routine with the same name) might want to try LcVete's way
forum.linuxcnc.org/qtpyvcp/48373-qtpyvcp...llation-files-inside
29 Apr 2023 11:30 #270194
by tivoi
Replied by tivoi on topic Mini wannabe datron build
- ihavenofish
29 Apr 2023 11:31 #270195
by ihavenofish
as i said, i literally followed that to the letter.
This is where we ended up so far. most of the errors have been dumb stuff so far (network issues, installing as root, etc), now we are at this latest one.
- ihavenofish
29 Apr 2023 11:32 #270197
by ihavenofish
thanks
29 Apr 2023 11:34 #270198
2 replies, so which one did you follow?
One side note that gets missed sometimes, before installing LinuxCNC always, always do
sudo apt update
sudo apt upgrade
skipping this has a tendency of causing some issues later down the line despite LinuxCNC installing.
sudo apt update
sudo apt upgrade
Moderators: cncbasher
Time to create page: 0.199 seconds
