- Hardware & Machines
- CNC Machines
- Inexpensive Accelerometer balancing, tool breakage, chatter detection
14 Sep 2022 19:25 #251927
by lrak
I was thinking about balancing a lathe chuck and ran into this:
Which reminded me of the programs on cellphones for doing vibration testing..
Which led to this:
www.memsic.com/Public/Uploads/uploadfile...PS-048-0072v1.2).pdf
The chip for these runs less than a dollar. I'm thinking one could find a way to make a standalone one for LinuxCNC - seems like many would buy one for balancing/tool breakage - chatter detection (could vary speed if vibration is detected.)
These use a SPI or I2C interface.
I did a couple of quick searches here - didn't see where anyone else went down the same rabbit hole?
Which led to this:
The following user(s) said Thank You: arvidb
14 Sep 2022 23:45 #251956
Replied by andypugh on topic Inexpensive Accelerometer balancing, tool breakage, chatter detection
I keep meaning to implement this for LinuxCNC.
Which is very easy to do in HAL with existing components. The question is whether it should be built-in?
15 Sep 2022 01:13 #251962
Replied by cmorley on topic Inexpensive Accelerometer balancing, tool breakage, chatter detection
I had already done it at one time other then it was turned on and off with HAL pjns as I didnt know how to do m code stuff.
It would be on the maillist somewhere..
15 Sep 2022 01:46 #251964
So far I have just twiddled the FO MPG. Which works, too,
Indeed, just needs a siggen in HAL. As i said, the question is whether we build it in, or create a specfic HAL component.I had already done it at one time other then it was turned on and off with HAL pjns as I didnt know how to do m code stuff.
It would be on the maillist somewhere.I
15 Sep 2022 01:53 #251966
That's what I meant - I did build it into motion. I just didn't code a NML message to turn it on.
15 Sep 2022 15:59 #252009
by arvidb
Great video link too - thanks!
Replied by arvidb on topic Inexpensive Accelerometer balancing, tool breakage, chatter detection
Vibration monitoring would certainly be a nice feature. Since the chip you found has a max sample rate of 2 kHz it should be possible to get one sample per servo period. I haven't looked into it but the Mesa cards should be able to communicate via SPI (at least in theory; I haven't looked into actual support).I was thinking about balancing a lathe chuck and ran into this /.../
15 Sep 2022 19:35 - 15 Sep 2022 19:42 #252034
by jpg
Replied by jpg on topic Inexpensive Accelerometer balancing, tool breakage, chatter detection
good evening, some examples on dynamic balancing always around the ADXL335/345:
www.instructables.com/Simple-Rotor-Balancing-Machine/
Last edit: 15 Sep 2022 19:42 by jpg.
09 Oct 2022 19:58 #253822
by Bari
Replied by Bari on topic Inexpensive Accelerometer balancing, tool breakage, chatter detection
I vote for a HAL component vs built in. Keep things as flexible as possible.
10 Oct 2022 02:16 #253843
The problem of maximum flexibility is it is also the hardest to configure/.
By being built in, it would also standardize the g/m codes to use it.
I did find my code on a old disk drive. I'll have to dust it off and look at the code to see if it's worth moving forward with presenting to anyone.
Moderators: cncbasher
- CNC Machines
Time to create page: 0.107 seconds
