1 or 2 dedicated 120VAC circuits for my CNC?
- Thank you received: 5966
22 Mar 2023 22:33 #267328
Replied by tommylight on topic 1 or 2 dedicated 120VAC circuits for my CNC?
Use the Mist and/or Flood pins that already exist in LinuxCNC, just having those in hal will enable them and also show them in the Axis GUI.
Append the output pin to them, then in gcode adding M7 and/or M8 with M9 will happily turn on or off whatever is wired to those pins.
Something like
net coolant-flood hm2_pci-5i25.0.0.7i77.output-12
net coolant-mist hm2_pci-5i25.0.0.7i77.output-13
Edit the pins to suit your system/boards/wiring.
Something like
22 Mar 2023 22:52 #267329
by Sray69
Replied by Sray69 on topic 1 or 2 dedicated 120VAC circuits for my CNC?
Thanks Tommy. This will get me headed in the right direction. What if I am using gmoccopy? Will I have to do something different?Use the Mist and/or Flood pins that already exist in LinuxCNC, just having those in hal will enable them and also show them in the Axis GUI.
Something like
22 Mar 2023 23:19 #267331
The gcode should work, for sure if you add those line in hal, but not sure if you get the buttons on screen.
22 Mar 2023 23:31 #267333
by Sray69
OK so I added the following lines to my HAL file.
# external output signals
# --- ROUTER-ON ---
net coolant-mist => hm2_7i76e.0.7i76.0.0.output-15
# --- DUST-COLLECTOR-ON
net coolant-flood => hm2_7i76e.0.7i76.0.0.output-01
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
I am able to see them trigger ON in Halshow using M7 & M8. I can also trigger them OFF with M9. BUT when they are triggered ON there is no power to my circuits (Output pins 15 and 01). I must be missing something.
# --- ROUTER-ON ---
23 Mar 2023 00:14 #267337
Output
is the second pin on the header, not the first
just to be sure
just to be sure
23 Mar 2023 02:36 #267342
by Sray69
Yes I have it correct. It is the second pin.
23 Mar 2023 12:07 #267357
Use a DVM to measure the voltage change on that pin, if you can.
23 Mar 2023 12:09 #267358
Also, watch the output pin in halshow if it is changing state.
23 Mar 2023 16:16 #267369
by Sray69
I checked the pins and both pins are triggering in Halshow. Both pins are providing 24VDC when triggered.
Once I reconnected the wires and tested again, the router circuit now works as expected, but the dust collector circuit gives me a "Smart serial card remote error = (27) Over Current" error. I have researched this and I think my problem is that there is no flyback diode on the dust collector relay. Does this sound correct? If yes, can you tell me what diode I need to get and exactly how it should be soldered in?
24 Mar 2023 00:53 #267388
If you are getting over current warnings for Mesa outputs, the relay is way out of spec for current draw.
Having said that, any silicium diode will do, something like 1N4001 to 1N4007 will do just fine, wired in parallel to relay winding, just mind the polarity in regard to Mesa output.
I would use another smaller relay in between, or a transistor.
Moderators: cncbasher
Time to create page: 0.103 seconds
