Validating LinuxCNC Post for Autodesk CAM
16 Sep 2014 12:34 #51227
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Replied by RayJr on topic Validating LinuxCNC Post for Autodesk CAM
That file seems to be a table of contents, but other than that, it has no contents.
Ray
Ray
Albert Einstein
16 Sep 2014 16:25 #51235
It's a .chm file (Compiled Help Metafile) which is actually a really convenient container for documentation and files, but only generally usable on Windows systems and often stamped in quite hard by sscurity systems as it is also an easy way to package malicious code.
There are viewers for Linux:
www.linux.com/news/software/applications...hm-viewers-for-linux
Replied by andypugh on topic Validating LinuxCNC Post for Autodesk CAM
29 Oct 2014 09:12 #52518
by jonesturf
Replied by jonesturf on topic Validating LinuxCNC Post for Autodesk CAM
Pete,
Does this have fourth/fifth axis capability yet if you purchase the Pro software?
15 Jan 2015 09:08 #55020
I updated to 2014 today and installed HSM Express
My first thought is that by being integrated into Inventor it is very slick and very convenient.
it would be good to change the name of the EMC post-processor. Due to legal problems with the EMC corporation we have been forced to change the name of the software. It has been LinuxCNC for quite a long time now.
I haven't got very far with it yet. It looks like I will need to modify my model to have sharp contours and faces. It seems something of an oversight to have "project geometry" when modelling, and not (as far as I can see) in the CAM. This is a fairly extensively-used process in CamBam (mainly because of how it works). Perhaps I just haven't found it yet.
I confess the part in question is not an ideal 2.5D part, I am expecting to have to change setups a number of times, then do some manual rotary-axis work.
I may try the 5-axis trial in a few weeks, but with only 30 days and a holiday coming up the timing is not ideal.
14 Apr 2015 04:32 #57769
Well, I did, and I am very impressed. The Pro CAM is very nice indeed.
Unforunately, as a hobbyist, it is way outside my budget, but if I was making a living at this I would certainly consider it.
04 Nov 2015 00:49 #64720
I have recently found that Fusion 360 has identical CAM capabilities to Inventor HSM Pro and is much cheaper.
In fact, for hobby use or startups making less than $100k it is free. For commercial use it is $25 per month.
It only runs natively on Mac and Windows, but other than that it is hard to see anything that can compete at the price.
- kornphlake79
- Thank you received: 10
06 Nov 2015 10:45 #64868
by kornphlake79
Replied by kornphlake79 on topic Validating LinuxCNC Post for Autodesk CAM
I have been using fusion360 for a couple of months, I searched very hard for something inexpensive and as capable as the professional cad/cam packages and couldn't find anything that comes close to fusion360. Seimens has solidedge 2d and Dassault has Draftsight but neither is 3d and neither has an associated cam package, all they have in common with fusion360 is the cost and professional grade user interface.
I have gripes about fusion360 but that is a topic for another forum. In regards to the bundled emc post processor I have found it to be satisfactory for my use. My machine is a gantry router with roughly 12x20x1.5 travel. Because the z axis travel is so short I have the machine setup to search for the upper limit switch then back off -.05 for the a zero position. As I recall the default post processor geneated a line containing g53 z .1 at the start and end of the program which caused limit errors. I modified the post for my needs without reading any instructions on editing post processors, I found it to be no more difficult than editing config files in linux. I don't have a tool changer or spindle speed control or coolant that could potentially be a problem.
- yoshimitsuspeed
08 Nov 2015 19:03 #64980
by yoshimitsuspeed
Replied by yoshimitsuspeed on topic Validating LinuxCNC Post for Autodesk CAM
This is my take on Fusion 360 in it's current state.
If you are a personal user or one person operation and money is more important than time and if you fall under the free use license it's a great bang for the buck.
If you have employees who will be paid to use the software then you will loose more time and money paying them to deal with crashes, bugs, glitches, lack of features and switching over to other CAD programs to fill in the gaps than you would spend on a better CAD package. In the latter case I would bite the bullet and buy something that is better developed and more capable.
- yoshimitsuspeed
08 Nov 2015 19:05 #64981
by yoshimitsuspeed
08 Nov 2015 19:06 #64982
I am only really recommending it for CAM. It definitely isn't pro-level CAD.
But, if you are in that position, Inventor + CAM is £7500 and that is probably what you would choose.
Moderators: Skullworks
Time to create page: 0.341 seconds
