cad/cam for cnc router & lathe
15 May 2015 17:34 #58722
by BigJohnT
Replied by BigJohnT on topic cad/cam for cnc router & lathe
I use Sheetcam for my plasma cutter. Took some fiddling with the post processor to make it work for my needs.
JT
JT
15 May 2015 17:46 #58725
Yes. And both work under Linux too. (using Wine in the case of MeshCAM)
www.grzsoftware.com/users/linux-cnc/
www.sheetcam.com/downloads
CamBam runs natively on Linux: www.cambam.info/ref/ref.linux
None of the above are Open Source as far as I know.
Replied by andypugh on topic cad/cam for cnc router & lathe
Meshcam & sheetcam output compatible code for linuxcnc?
27 Dec 2018 23:18 #122986
by clunc
Replied by clunc on topic cad/cam for cnc router & lathe
+1 for Meshcam.
Have used it for years, stably, in Linux, using Wine (both 32- and 64-bit versions; you have to make sure the Linux WINEDIR_PREFIX variable is set correctly, whatever its correct name is, before launching the latter).
Meshcam also permits customization of, or brand-new, configuration files (the .CON files in the \POSTS\ directory). Meshcam reads in a 3D model file (or a 2D black-and-white drawing for which it will interpret relative brightness as depth), and generate G-code in the "flavor" of whatever post-processor you select (to match the machine to run it).
29 Mar 2019 16:29 #129907
by Vitran
Replied by Vitran on topic cad/cam for cnc router & lathe
What about lathes specifically?
What CAM can produce things like parting, profiles, drilling, and threading on the lathe? We use Autodesk Inventor Professional which does not include HSM for lathes. I own a license of CamBam, but as far as I can tell it does not have much lathe capability shy of 'follow the curve' and compensate for tip radius but not tool direction.
Has anyone have any luck with Fusion 360 CAM for lathe work? Is it free for use?
My current guess is I will be writing a lot of threading/facing/parting commands by hand.
29 Mar 2019 17:02 #129910
Yes, in fact I used it last night. I have a postprocessor for LinuxCNC lathe but can't remember where it came from. Nor do I know if the standard LinuxCNC postprocessor now works properly (it is quite likely that it does)Has anyone have any luck with Fusion 360 CAM for lathe work?
It can be, but only for non-profit or startup companies.Is it free for use?
30 Mar 2019 02:02 #129953
by cmelojr
It's good, haven't used it for Linuxcnc but with Okuma Lathes. It's not as robust as the milling CAM is but it's quite good. In many ways I prefer it over Mastercam.
Replied by cmelojr on topic cad/cam for cnc router & lathe
30 Mar 2019 08:21 - 30 Mar 2019 08:23 #129958
by pl7i92
Replied by pl7i92 on topic cad/cam for cnc router & lathe
For Standard parts heekcnc can do lathe
it is on a Repro for Linux
launchpad.net/~neomilium/+archive/ubuntu/heekscnc-devel
Last edit: 30 Mar 2019 08:23 by pl7i92. Reason: link
Moderators: Skullworks
Time to create page: 0.099 seconds
