HSMExpress
14 May 2015 18:08 - 14 May 2015 19:41 #58672
by BigJohnT
HSMExpress was created by BigJohnT
I edited the post processor for the free HSMExpress to remove the useless line numbers and percent signs and renamed it linuxcnc.
JT
JT
Last edit: 14 May 2015 19:41 by BigJohnT.
- LearningLinuxCNC
- Thank you received: 61
08 Jun 2015 08:09 #59613
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic HSMExpress
Does this post processor also work with Inventor HSM? I have been using it with my router I plan on using it with my mill once I get it finished.
08 Jun 2015 18:24 #59620
by BigJohnT
Replied by BigJohnT on topic HSMExpress
I have no idea, I had to remove Hmsexpress from my machine because it slowed down SolidWorks too much.
JT
JT
08 Jun 2015 23:57 #59630
Replied by andypugh on topic HSMExpress
Yes, it works with Inventor HSM
29 Jun 2015 03:38 #60233
by thewho
Replied by thewho on topic HSMExpress
When on the topic of HSMExpress/Works, how do people set up their tool libraries? I've never used tool libraries and offsets before as I didn't have enough toolholders.
For example:
Tool 1 = Probe, Offset = 0
Tool 2 = Face Mill, Offset = -30
Tool 3 etc..
Is that how you normally do it?
And then set the same tool numbers in express/works?
For example:
Tool 3 etc..
29 Jul 2015 01:23 #61000
by cncbasher
Replied by cncbasher on topic HSMExpress
use one or the other not both , i prefer to have offsets in the cam software , that leaves the tool table in linuxcnc as empty values or 0.0
and then use the tooltable for wear offsets only .
this way you'll never have the gcode specifc , and can move around different machines or operations
if you try as add the information to both the cam and the tooltable in linuxcnc , you'll end up adding the values , which of course is totally wrong
09 Sep 2015 04:42 - 09 Sep 2015 04:44 #62287
by BetaMax
Hey BigJohn, what CAM solution did you move to? I'm evaluating different solutions at the moment and Delcam and HSM both seem well integrated into Solidworks.
Thanks!
Max
Replied by BetaMax on topic HSMExpress
JT
Thanks!
Max
Last edit: 09 Sep 2015 04:44 by BetaMax. Reason: added quote
Moderators: Skullworks
Time to create page: 0.528 seconds
