ViaConstructor - Free and Opensource CAM for Linux and Mac
- Thank you received: 5956
27 Sep 2022 11:56 #252847
Replied by tommylight on topic ViaConstructor - Free and Opensource CAM for Linux and Mac
I gave it a try on one of my PC's, it installed vut did not run, will try again whenever i get some time.
This was on Linux Mint 20.?, not sure what exact version that PC is using.
Probably Python versions as Mint uses quite old versions of it.
It seems to be very nice and easy to use, thank you.
27 Sep 2022 18:26 #252876
by hottabich
Replied by hottabich on topic ViaConstructor - Free and Opensource CAM for Linux and Mac
Works on macOS High Sierra. Installed according to the instructions.
01 Oct 2022 05:00 #253145
by phillc54
Replied by phillc54 on topic ViaConstructor - Free and Opensource CAM for Linux and Mac
A small issue, straight leadins or leadouts start on the wrong side of the cut, swapping the additions and subtractions in if lead_in_active == "straight": and if lead_out_active == "straight": appears to work ok.
Arcs seem to be ok.
Arcs seem to be ok.
01 Oct 2022 10:21 #253156
Plasma cutting = no lead outs.
01 Oct 2022 10:30 #253159
by phillc54
Uncheck the leadout box?
The following user(s) said Thank You: tommylight, meister
01 Oct 2022 10:39 #253160
Did not check it yet as it did not work on Mint 20.2, now i have to see if it works on Mint 21 and i also have a laptop with the official 2.8.4 ISO installed.
That should work!Uncheck the leadout box?
01 Oct 2022 23:18 #253208
by phillc54
I am running it on a mac. My buster VM only has python 3.7 and this needs 3.9 or later.
02 Oct 2022 01:36 #253214
Works on Mint 21.
04 Oct 2022 09:18 #253425
by meister
Replied by meister on topic ViaConstructor - Free and Opensource CAM for Linux and Mac
phillc54
i have not been able to recreate the mouse problem on mac. if it still does not work, can you send me your configuration and or your test file
'straight lead in/out' is fixed, thanks !
Moderators: Skullworks
Time to create page: 0.121 seconds
