Remapping: Was: Stand Alone Interpe r ter
29 May 2019 17:02 #135300
by bevins
Oh, it is long and complicated but the short story is, after four or five running of the same file and cutting, the interpreter just stops executing commands. IT just stops, the spindle still running, and no more commands are executed. The queue is empty, there are no errors, just stops.
Its been a long haul;, but, it is a known issue if you dig back into the threads and mailing list. IT is a pure python remap, and I cant get help on it because no one really understands the inner workings I guess I can say, except one person that just doesn't respond to questions. They do say you are on your own when you go this route.
but I would like to play with the stand alone interpreter, and I may get some kind of direction.
This is my config. Sorry, didnt mean to hijack this thread.
Replied by bevins on topic Stand Alone Interpe r ter
@Bevins,
I am curious wich command's are ignored and what the bug's in remap are in your vision?
Maybe i can tell you some tip's after your info, maybe not
29 May 2019 18:16 - 29 May 2019 18:22 #135311
by Grotius
Replied by Grotius on topic Stand Alone Interpe r ter
@Bevins,
I never had this issue. Linux is stable as hell in my case. Is your machine pc at internet? In worst case you are hacked.
Hmm. Why that? It can be monitored on several way's.
If you need some hijacked contact adresses. Please visit : darknetleaks.ru/archive/leaked/Dumps/FBI.txt
Last edit: 29 May 2019 18:22 by Grotius.
29 May 2019 19:05 #135315
by bevins
I am not quite understanding your comments but....
I know Linuxcnc is stable. I have done many machine retrofits and building from scratch.
Pure Python remaps are very tedious and unpredictable. That is coming from the fellow that wrote the remap part of Linuxcnc.
This issue is documented in mailing lists. My machine is not hacked, it cannot be cause it is not connected to the internet.
@Bevins,
- Thank you received: 1370
29 May 2019 19:47 #135318
Replied by Todd Zuercher on topic Stand Alone Interpe r ter
Maybe the problem isn't the interpreter, but the way the python remaps interact with it. (from the sound of it, the developer who created it is suspicious of that.)
Can you make your remaps work without using python?
30 May 2019 01:58 - 30 May 2019 01:59 #135341
by bevins
That's pretty much it. From what I understand the interpreter is not the master of its domain so it needs input from task before it can process commands. Or it's dependent on other processes or a combination , it just cannot execute by itself. Plus there is an issue of python not being able to process a sequence of functions, that's why you cannot use Standard glue with a remap in pure python. You have to put the functions standard glue has in the remap function, which is what I did and it works.
I am pretty sure it would work with oword ngc, but I know nothing about that and I guess it is not documented in one place where I can read and understand. I know of a guy that did the same type of machine with remapping M codes to fire all the relays but he didnt need to move the axis as he had no tool changer just 30 some odd number of gang drills.
I got everything working tool changes drill gangs but after a certain number of times processing the program, it just stops dead in it's tracks.
Last edit: 30 May 2019 01:59 by bevins.
30 May 2019 09:48 #135372
I would say that if you need to move axes then it is a much better idea to use an O-word sub than to use pure Python. (I imagine that your Python uses MDI commands to move axes? Though you can do it with canonical movement commands too.)
You don't need M-codes to operate relays, G-code can toggle HAL pins directly, and has built-in codes to wait for HAL pin inputs to change.
Look at this G-code tool change sub, it sets HAL pins using M64 / M65 and uses M66 to wait for inputs confirming that the mechanisms are in position.
github.com/LinuxCNC/linuxcnc/blob/master...hange/toolchange.ngc
Replied by andypugh on topic Remapping: Was: Stand Alone Interpe r ter
30 May 2019 11:04 - 30 May 2019 11:05 #135374
by bevins
Here is my main remap file. You think ngc oword could do this?
There is alot of code I am not using in there.
Replied by bevins on topic Remapping: Was: Stand Alone Interpe r ter
Warning: Spoiler!
#!/usr/bin/env python
# Mar 2017 Code by Michel Trahan, Bob Bevins and Sylvain Deschene
# Remap of M6 in Pure Python, remap.py includes change_epilog
# Machine is Biesse 346 1995, with 3 position rack toolchanger
import linuxcnc
from interpreter import *
import emccanon
from util import lineno
throw_exceptions = 1 # raises InterpreterException if execute() or read() fail
import xmlBiesse
import sys
# MAIN FUNCTION : change_remap
# REMAP=M6 modalgroup=6 python=M6_Remap_BiesseRover346
# - Do not use stdglue.py, in pure python remap
def queuebuster(self, **words):
yield INTERP_EXECUTE_FINISH
def M6_Remap_BiesseRover346(self, **words):
# if in preview mode exit without doing anything and all ok
if self.task==0:
return INTERP_OK
#else:
# DoYield()
change_prolog1(self, **words)
try:
# Get the xmlfile path from the ini file ... or hardcode here
# [XML]
# FILE=/home/bob/linuxcnc/configs/python/BiesseRover346.xml
xmlfile = "/home/bob/linuxcnc/configs/python/BiesseRover346.xml"
# XML - Objects to fetch needed infos ...
self.x = xmlBiesse.xmlBiesse(xmlfile) # the xml interface
# set some self values
self.feedSpeed = self.x.getFeedSpeed()
self.pulseDelay = self.x.getDelay("pulseDelay")
self.stat = linuxcnc.stat()
self.HIGH = 1
StopSpindleNow(self)
# test if spindle has really stopped
self.stat.poll()
index = self.x.getSignalInfos("spindleHasStopped")
isSpindleStopped = int(self.stat.din[index])
if isSpindleStopped != 1:
msg = "Spindle has not stopped even after M66"
self.set_errormsg(msg)
return ReturnERROR()
# we are good to go
print("Spindle Stopped")
# raise the Z
MoveZtoZero(self)
# raise all spindles
print("Lets just try raising A,B and C for now")
raisespindlesABC(self)
#raiseALLspindles(self)
print("ALL Spindle Raised")
# De Energise all spindles
DeEnergiseALLSpindle(self)
print("ALL Spindles DeEnergised")
# now go according to selected_tool given by linuxcnc for the Txxx M6 ngc command
selectedtool = int(self.params["selected_tool"])
self.selected_tool = int(self.params["selected_tool"])
print("Selected Tool : %d" % selectedtool)
if selectedtool > 700: # 701 to ... any combinations of drills and side drills
DropTools(self, selectedtool)
self.current_tool = selectedtool
self.current_pocket = selectedtool
self.execute("G43 H%d" % selectedtool)
elif (selectedtool > 500 and selectedtool < 510): # 5 pairs of side drills (1,3,5,7,9)
DropSideDrill(self, selectedtool - 500)
elif (selectedtool > 400 and selectedtool < 434): # 33 drills (1-33)
DropDrill(self, selectedtool - 400)
else:
if selectedtool == 21:
if SpindleHasTool(self, "C"):
DropSpindleC(self)
EnergiseSpindle(self, "C")
#This is if you have three ISO spindles. This is spindle#3 or C
return INTERP_OK
else:
msg = "Spindle C has no tool"
elif selectedtool == 20:
if SpindleHasTool(self, "B"):
DropSpindleB(self)
EnergiseSpindle(self, "B")
SetG43Tool20(self)
#This is if you have three ISO spindles. This is spindle#2 or B
return INTERP_OK
else:
msg = "Spindle B has no tool"
elif selectedtool > 0 and selectedtool < 4: #only 3 tools for A (1, 2, 3)
EnergiseSpindle(self, "A")
# now time to see if already in spindle
freePocket = FindFreePocket(self)
self.current_pocket = freePocket
print("freePocket = %s" % freePocket)
currenttool = int(self.params["tool_in_spindle"])
print("tool in spindle = %s" % currenttool)
if freePocket == -1:
# what is in spindle 1 ? check if spindle has tool
if SpindleHasTool(self, "A"): # we have a problem
msg = "No Free Pockets and Spindle A has a tool"
else: # if not, go get the one needed
# PICKUP selected tool in according pocket
print("Spindle A has no tool, going to PickUpNewTool %d" % selectedtool)
OpenCasket(self)
if selectedtool == 1: #Pickup Tool 1
PickUpTool1(self)
CloseCasket(self)
# self.current_tool = 1
elif selectedtool == 2: #Pickup Tool 2
PickUpTool2(self)
#SetG43Tool2(self)
CloseCasket(self)
# self.current_tool = 2
elif selectedtool == 3: #Pickup Tool 3
PickUpTool3(self)
CloseCasket(self)
# self.current_tool = 3
return INTERP_OK
else:
print("There is a free pocket")
# check if spindle has tool
if not SpindleHasTool(self, "A"):
msg = "Error while droping a tool, Spindle A has no tool to drop"
self.set_errormsg(msg) # replace builtin error message
print("Spindle A has tool, do drop it")
# check if tool already in spindle
if freePocket == selectedtool:
DropSpindleA(self)
print("Spindle A already has the right tool")
return INTERP_OK
# DROP current tool in free pocket
OpenCasket(self)
if freePocket == 1:
DropTool1(self)
PickUpTool2(self)
elif selectedtool ==3:
PickUpTool3(self)
CloseCasket(self)
DropSpindleA(self)
return INTERP_OK
elif freePocket == 2:
DropTool2(self)
PickUpTool1(self)
PickUpTool3(self)
CloseCasket(self)
DropSpindleA(self)
return INTERP_OK
elif freePocket == 3:
DropTool3(self)
PickUpTool2(self)
elif selectedtool ==1:
PickUpTool1(self)
CloseCasket(self)
DropSpindleA(self)
return INTERP_OK
else: # not > 700, not between 400 and 434 (exclusive), not between 500 and 510 (exclusive), nor 0,1,2,3,10,11
msg = "Wrong tool number either 0 to remove it from spindle or 1,2,3,20,21\n"
msg += "Or 401 to 433 for drills, 501, 503, 505, 507, 509 for side drills,\n"
msg += "701 to whatever is defined in the tool table AND the xml file\n"
msg += "Tool given was: %d" % selectedtool
# We have errors ! catch and return error
except InterpreterException,e:
msg = "BOB look at this error : %d: '%s' - %s" % (e.line_number,e.line_text, e.error_message)
print("%s" % msg)
except IOError as e:
print "I/O error({0}): {1}".format(e.errno, e.strerror)
except ValueError:
print "Could not convert data to an integer."
except ZeroDivisionError as detail:
print 'Handling run-time error:', detail
except:
print "Unexpected error:", sys.exc_info()[0]
raise
finally:
print 'Hold on, off to epilog coming up!'
print("Current pocket = %s" % self.current_pocket)
print("Selected pocket = %s" % self.selected_pocket)
print("Param.Selected pocket = %s" % int(self.params["selected_pocket"]))
print("Current tool in spindle = %s" % self.current_tool)
print("Selected tool = %s" % self.selected_tool)
self.return_value = self.selected_tool
# all fine, return ok !
# This is the change_epilog within remap body
print 'Final!'
print("Self return value = %s" % self.return_value)
print 'calling epilog'
print 'Returned form epilog journey'
self.selected_pocket = int(self.params["selected_pocket"])
print("before emccannon CHANGE TOOL")
emccanon.CHANGE_TOOL(self.selected_pocket)
print("emccannon CHANGE TOOL sent")
self.current_pocket = self.selected_pocket
#self.selected_pocket = -1
#self.selected_tool = -1
# cause a sync()
print("Lets Sync this Bitch, NOW")
self.set_tool_parameters()
self.toolchange_flag = True
return INTERP_OK
def change_prolog1(self, **words):
try:
if self.selected_pocket < 0:
return "M6: no tool prepared"
if self.cutter_comp_side:
return "Cannot change tools with cutter radius compensation on"
self.params["tool_in_spindle"] = self.current_tool
self.params["selected_tool"] = self.selected_tool
self.params["current_pocket"] = self.current_pocket
self.params["selected_pocket"] = self.selected_pocket
return INTERP_OK
except Exception, e:
return "M6/change_prolog: %s" % (e)
def change_epilog(self, **words):
try:
#print("Change epilog executing....")
if self.return_value > 0.0:
print("pass return value")
# cause a sync()
else:
self.set_errormsg("M6 aborted (return code %.1f)" % (self.return_value))
return
self.set_errormsg("M6/change_epilog: %s" % (e))
return
#-----Set me some tool offsets here!!!---------------------
def SetG43Tool20(self):
self.execute("G43 H20")
def SetG43Tool2(self):
self.execute("G43 H2")
def DropSpindleA(self):
self.execute("M64 P2") #Drop Spindle
self.execute("G4 P1") #wait to release pulse on lock spindle
self.execute("M65 P2") #Release drop SP relay, only needs pulse
self.execute("M66 P9 L3 Q5")
print("drop Spindle A Done") #Wait for Spindle to drop
def DropSpindleB(self):
index = self.x.getSignalInfos("spindleBdrop")
self.execute("M64 P%d" % index)
self.execute("G4 P0.5")
self.execute("M65 P%d" % index)
index = self.x.getSignalInfos("spindleBdown")
self.execute("M66 P%d L4 Q1" % index)
#self.execute("M64 P3")
#self.execute("G4 P0.5")
#self.execute("M65 P3")
#self.execute("M66 P10 L4 Q1")
print("DropSpindle(B) done")
def DropSpindleC(self):
self.execute("M64 P4")
self.execute("M65 P4")
self.execute("M66 P11 L4 Q1")
print("DropSpindle(C) done")
def DropTool1(self):
#id = 1
#posX, posY, posZ = self.x.getPocketPos(id, "Front")
self.execute("G53 G0 X15.375 Y-25.57 Z0") #Move to front of pocket 1
#self.execute("G53 G0 F%d X%f Y%f Z0.0" % (self.feedSpeed, posX, posY), lineno())
self.execute("M64 P2") #Drop Spindle A
self.execute("M66 P9 L3 Q5") #Wait for Spindle to drop
self.execute("M64 P10") #raise Pocket 1
self.execute("M66 P17 L3 Q5") #wait for Pocket to raise
self.execute("G53 G0 Z-1.788") #Drop the Z into position
#self.execute("G53 G0 F%d Z%f" % (self.feedSpeed, posZ), lineno())
self.execute("G53 G1 F200 X11.825") #Move into pocket to release tool
#posX2, posY2, posZ2 = self.x.getPocketPos(id, "Top")
#self.execute("G53 G1 F%d X%f " % (self.feedSpeed, posX2),lineno())
self.execute("M66 P4 L3 Q5") #Wait for pocket 1 has tool
self.execute("M64 P8") #Release Spindle
self.execute("M66 P13 L3 Q5") #Wait for Spindle to release
self.execute("M64 P5") #Raise Spindle
self.execute("M66 P7 L3 Q5") #Wait for Spindle to raise
self.execute("G53 G0 Z0") #Move to Z0
self.execute("M65 P8") #Release Sp A pulse relay, only needs pulse
self.execute("M64 P9") #Lock Spindle A
self.execute("G4 P1.0") #wait to release pulse on lock spindle
self.execute("M65 P9") #release Lock Spindle A, only needs pulse
self.execute("M65 P10") #Lower Pocket 1
#self.execute("G1 G53 F%d Z%f" % (self.feedSpeed, posZ), lineno())
#INTERP_EXECUTE_FINISH
def DropTool2(self):
self.execute("G53 G0 X15.375 Y-33.527 Z0") #Move to front of pocket 2
self.execute("M64 P11") #raise Pocket 2
self.execute("M66 P18 L3 Q5") #wait for Pocket to raise
self.execute("G53 G0 Z-1.840") #Drop the Z into position
self.execute("G53 G1 F200 X11.900") #Move into pocket to release tool
#self.execute("M66 P5 L3 Q5") #Wait for pocket 2 has tool
self.execute("M65 P8") #Release Sp B pulse relay, only needs pulse
self.execute("M65 P11") #Lower Pocket 2
def DropTool3(self):
self.execute("G53 G0 X15.375 Y-41.545 Z0") #Move to front of pocket 3
self.execute("M64 P12") #raise Pocket 3
self.execute("M66 P19 L3 Q5") #wait for Pocket to raise
self.execute("G53 G0 Z-1.790") #Drop the Z into position
#self.execute("M66 P6 L3 Q5") #Wait for pocket 3 has tool
self.execute("M65 P12") #Lower Pocket 3
def PickUpTool1(self):
self.execute("G53 G0 X11.825 Y-25.57 Z0") #Move to top of pocket 1
#self.execute("M66 P13 L3 Q5") #Wait for Spindle to release
self.execute("M65 P8") #Release Rel Spindle. only needs a pulse
self.execute("G4 P0.5") #wait to release pulse on lock spindle
#self.execute("M66 P12 L3 Q5") #Wait for spindle Has Tool 1
self.execute("G53 G0 X15.375") #Move out to front of pocket 1
self.execute("M66 P7 L3 Q2") #Wait for Spindle to raise
self.execute("M65 P5") #RAise spindle release only pulse needed
def PickUpTool2(self):
self.execute("G53 G0 X11.900 Y-33.537 Z0") #Move to top of pocket 2
self.execute("G53 G0 X15.375") #Move out to front of pocket 2
def PickUpTool3(self):
self.execute("G53 G0 X11.825 Y-41.545 Z0") #Move to top of pocket 3
#self.execute("M66 P12 L3 Q5") #Wait for spindle Has Tool 3
self.execute("G53 G0 X15.375") #Move out to front of pocket 3
def raisespindlesABC(self):
#Raising Spindle A, B, C
self.execute("M64 P6")
self.execute("M64 P7")
self.execute("M65 P6")
self.execute("M65 P7")
# loop through all drills
for i in range(1, 34, 1):
self.execute("M65 P%d" % (int(i) + 15))
# loop through all side drills
for i in range(1, 6, 1):
self.execute("M65 P%d" % (int(i) + 48))
def CloseCasket(self):
self.execute("M64 P1", lineno())
self.execute("G4 P0.5", lineno())
self.execute("M65 P1", lineno())
def OpenCasket(self):
self.execute("M64 P0", lineno())
self.execute("M65 P0", lineno())
self.execute("M66 P2 L3 Q5", lineno())
def CheckDIN(self, sWhich, doPoll):
index = self.x.getSignalInfos(sWhich)
if doPoll:
self.stat.poll()
return(int(self.stat.din[index]))
def CheckDOUT(self, sWhich, doPoll):
if doPoll:
self.stat.poll()
#print("signal:%s index= %d" %(sWhich, index))
return(int(self.stat.dout[index]))
def SendDOUT(self, sWhich, val):
# only call M6x if not already at desired value
if CheckDOUT(self, sWhich, True) != val:
self.execute("M6%d P%d" % (4 if val == 1 else 5, index),lineno())
def WaitOnSignalToBecome(self, sWhich, val, sSec): # val = 0 (L2) val = 1 (L1)
self.execute("M66 P%d L%d Q%f" % (index, 4 if val == 0 else 3, sSec), lineno())
def WaitAFewSeconds(self, sSec):
self.execute("G4 P%f" % sSec, lineno())
# M5 command to stop the spindle, here to clean up Spindle class,
# not in moves so we don't give moves to spindle class ...
def StopSpindleNow(self):
self.execute("M5", lineno())
# Now lets stop the drill spindle if running
self.execute("M65 P54")
# Wait for signal spindleHasStopped to go high
delay = self.x.getDelay("spindlehasstopped")
#self.execute("M66 P%d L3 Q%f"" % (index, delay), lineno())
self.execute("M66 P8 L3 Q15")
print("Stop Spindle command sent")
def MoveZtoZero(self):
self.execute("G53 G0 Z0.0",lineno())
print("Moved to Z = 0.0")
def SetToolOffsets(self):
self.execute("G43")
def isSpindleReallyStopped(self):
isSpindleStopped = CheckDIN(self, "spindleHasStopped", True)
print("isSpindleStopped = %s" % isSpindleStopped)
if isSpindleStopped == 1:
return True
else:
return False
# raising all spindles ... to make sure they are all raised
def raiseALLspindles(self):
# loop through all spindles
# check first if all spindle are already up
print("raiseALLspindles")
isSpindleALLup = CheckDIN(self, "spindleALLup", True)
if isSpindleALLup == 0:
# nope some are down, so put them all up
validSpindle = ("A", "B", "C")
for i in validSpindle:
RaiseSpindleNoCheck(self, i)
WaitOnSignalToBecome(self, "spindleALLup", self.HIGH, self.x.getDelay("spindleALLup"))
print("ERROR: SpindleAllup not true") #we have an error
RaiseDrill(self, i)
for i in range(1, 11, 2):
RaiseSideDrill(self, i)
print("All spindles, drills, and side drills are raised")
def EnergiseSpindle(self, sWhich):
# Deenergise if not selected
if sWhich != "A":
self.execute("M65 P13")
if sWhich != "B":
self.execute("M65 P14")
if sWhich != "C":
self.execute("M65 P15")
# Energise if selected
if sWhich == "A":
self.execute("M64 P13")
elif sWhich == "B":
self.execute("M64 P14")
elif sWhich == "C":
self.execute("M64 P15")
# wait a second
print("EnergiseSpindle(%s) done" % sWhich)
#self.execute("M64 P13")
#self.execute("M65 P14")
#self.execute("M65 P15")
#self.execute("G4 P1.0")
def DeEnergiseALLSpindle(self):
print("DeEnergiseALLSpindle done")
def SpindleHasTool(self, sWhich):
doesSpindleHasTool = CheckDIN(self, "spindle%shastool" % sWhich, True)
if doesSpindleHasTool == 0:
print("Spindle has no tool")
return False
else:
print("Spindle has tool")
return True
def DropDrill(self, sWhich):
index = self.x.getSignalInfos("spindle%ddrop" % sWhich)
self.execute("M64 P%d" % (index))
self.execute("M64 P54")
print("DropDrill(%s) done" % sWhich)
def RaiseDrill(self, sWhich):
self.execute("M65 P%d" % (index))
print("RaiseDrill(%s) done" % sWhich)
def DropSideDrill(self, sWhich):
index = self.x.getSignalInfos("spindle%dand%ddrop" % (int(sWhich), int(sWhich) + 1))
print("DropSideDrill(%s) done" % sWhich)
def RaiseSideDrill(self, sWhich):
print("RaiseSideDrill(%s) done" % sWhich)
def DropTools(self, sWhich):
drillList, sidedrillList = self.x.getMultiToolsLists(sWhich)
# drop the drills found
for d in drillList:
DropDrill(self, d)
# drop the side drills found
for d in sidedrillList:
DropSideDrill(self, d)
print("DropTools(%s) done" % sWhich)
def FindFreePocket(self):
# for each pocket defined, check if it has a tool
# if pocket does not have a tool, return that pocket number
# Query stat digital input status
pocket1hastool = CheckDIN(self, "pocket1hastool", True)
pocket2hastool = CheckDIN(self, "pocket2hastool", True)
pocket3hastool = CheckDIN(self, "pocket3hastool", True)
print("%s - %s - %s" % (pocket1hastool, pocket2hastool, pocket3hastool))
if pocket1hastool == 1:
if pocket2hastool == 1:
if pocket3hastool == 1:
return -1 # all pockets have something
else:
return 3 # pocket 3 has no tool
else:
return 2 # pocket 2 has no tool
else:
return 1 # pocket 1 has no tool
def DoYield():
print("In DoYield()")
# ReturnOK()
def ReturnOK():
print("Calling DoYield()")
DoYield()
print("After DoYield(), before return INTERP_OK")
return INTERP_OK
# ReturnERROR()
def ReturnERROR():
# if DoYield() is needed but I think not
#DoYield()
print("Before return INTERP_ERROR")
return INTERP_ERROR
# emc_status(actualtask)
# return tuple (task mode, task state, exec state, interp state) as strings
#self.stat.poll()
#task_mode = ['invalid', 'MANUAL', 'AUTO', 'MDI'][self.s.task_mode]
#task_state = ['invalid', 'ESTOP', 'ESTOP_RESET', 'OFF', 'ON'][self.s.task_state]
#exec_state = ['invalid', 'ERROR', 'DONE',
# 'WAITING_FOR_MOTION',
# 'WAITING_FOR_MOTION_QUEUE',
# 'WAITING_FOR_IO',
# 'WAITING_FOR_PAUSE',
# 'WAITING_FOR_MOTION_AND_IO',
# 'WAITING_FOR_DELAY',
# 'WAITING_FOR_SYSTEM_CMD' ][self.s.exec_state]
#interp_state = ['invalid', 'IDLE', 'READING', 'PAUSED', 'WAITING'][self.s.interp_state]
def emc_status(actualtask):
s = linuxcnc.stat()
s.poll()
task_mode = s.task_mode
task_state = s.task_state
exec_state = s.exec_state
interp_state = s.interp_state
#actualtask = self.task
sReturn = "---------------------------------------------------------\n"
sReturn += "task_mode values are :\n"
sReturn += "MODE_MANUAL : %d \n" % (linuxcnc.MODE_MANUAL)
sReturn += "MODE_AUTO : %d \n" % (linuxcnc.MODE_AUTO)
sReturn += "MODE_MDI : %d \n" % (linuxcnc.MODE_MDI)
sReturn += "task_mode = %d \n" % (task_mode)
sReturn += "\n"
sReturn += "task_state values are :\n"
sReturn += "STATE_ESTOP : %d \n" % (linuxcnc.STATE_ESTOP)
sReturn += "STATE_ESTOP_RESET : %d \n" % (linuxcnc.STATE_ESTOP_RESET)
sReturn += "STATE_OFF : %d \n" % (linuxcnc.STATE_OFF)
sReturn += "STATE_ON : %d \n" % (linuxcnc.STATE_ON)
sReturn += "task_state = %d \n" % (task_state)
sReturn += "\n"
sReturn += "exec_state values are :\n"
sReturn += "EXEC_ERROR : %d \n" % (linuxcnc.EXEC_ERROR)
sReturn += "EXEC_DONE : %d \n" % (linuxcnc.EXEC_DONE)
sReturn += "EXEC_WAITING_FOR_MOTION : %d \n" % (linuxcnc.EXEC_WAITING_FOR_MOTION)
sReturn += "EXEC_WAITING_FOR_MOTION_QUEUE : %d \n" % (linuxcnc.EXEC_WAITING_FOR_MOTION_QUEUE)
sReturn += "EXEC_WAITING_FOR_IO : %d \n" % (linuxcnc.EXEC_WAITING_FOR_IO)
#sReturn += "EXEC_WAITING_FOR_PAUSE : %d \n" % (linuxcnc.EXEC_WAITING_FOR_PAUSE) This does not exist
sReturn += "EXEC_WAITING_FOR_MOTION_AND_IO : %d \n" % (linuxcnc.EXEC_WAITING_FOR_MOTION_AND_IO)
sReturn += "EXEC_WAITING_FOR_DELAY : %d \n" % (linuxcnc.EXEC_WAITING_FOR_DELAY)
sReturn += "EXEC_WAITING_FOR_SYSTEM_CMD : %d \n" % (linuxcnc.EXEC_WAITING_FOR_SYSTEM_CMD)
sReturn += "exec_state = %d \n" % (exec_state)
sReturn += "\n"
sReturn += "interp_state values are :\n"
sReturn += "INTERP_IDLE : %d \n" % (linuxcnc.INTERP_IDLE)
sReturn += "INTERP_READING : %d \n" % (linuxcnc.INTERP_READING)
sReturn += "INTERP_PAUSED : %d \n" % (linuxcnc.INTERP_PAUSED)
sReturn += "INTERP_WAITING : %d \n" % (linuxcnc.INTERP_WAITING)
sReturn += "interp_state = %d \n" % (interp_state)
sReturn += "\n"
sReturn += "self.task = %d\n" % (actualtask)
sReturn += "---------------------------------------------------------\n"
return sReturn #(task_mode, task_state, exec_state, interp_state)
Last edit: 30 May 2019 11:05 by bevins.
30 May 2019 11:23 #135375
Well, in theory, yes, as any Turing-complete language can do anything that any other one can do.
I grant it might be difficult.
One thing that I am curious about is whether self.execute("G code here") is the best approach.
(Those bits would probably be _better_ done from a g-code sub).
The Python interface offers the command.mdi() way to run G-code. I wonder if that works better, worse or the same? It would be a simple search-and-replace job to try it.
Another option is the canonical command interface. That does not seem to be particularly well documented, but it is what I used in my G71 Python remaps:
github.com/LinuxCNC/linuxcnc/blob/andypu...python/remap.py#L443
Though I think it only uses emccanon.STRAIGHT_TRAVERSE and STRAIGHT_FEED
The canon commands are defined (and quite well described) in this file:
github.com/LinuxCNC/linuxcnc/blob/master...mc/nml_intf/canon.hh
30 May 2019 11:50 - 30 May 2019 11:56 #135376
by bevins
I used those commands because it was the only way I could get it to work in python. The problem was when I got into a few functions deep, I couldn't get it to respond to canon commands.
/EDIT Granted, I may not have done it correctly.... whether that was causing it to ignore commands or not, I am not sure.
Last edit: 30 May 2019 11:56 by bevins.
30 May 2019 11:52 #135377
Did you try the canonical commands?
I used those commands because it was the only way I could get it to work in python. The problem was when I got into a few functions deep, it wouldn't respond to commands.
Moderators: HansU
Time to create page: 0.220 seconds
