rem em ber - in Document QTvcp Development 5.6. Dialogs
05 Jun 2019 21:44 #135975
by partec
rem em ber - in Document QTvcp Development 5.6. Dialogs was created by partec
QTvcp Development
5.6. Dialogs
Dialogs (AKA pop up windows) are placed on the screen in Designer.
It doesn’t matter where on the layout but to make them hidden,
cycle the state property to true then false.
By default, if there is a preference file, the dialogs will
rem em ber their last size/placement. It is possible to override
this so they open in the same location each time.
remember
so many thanks to everybody doing all the great work, I love to use LinuxCNC all the time - many thanks
5.6. Dialogs
remember
- Thank you received: 5949
05 Jun 2019 22:48 #135978
Replied by tommylight on topic rem em ber - in Document QTvcp Development 5.6. Dialogs
Thnx for the info, someone will surely find it useful.
06 Jun 2019 03:58 #136006
Replied by cmorley on topic rem em ber - in Document QTvcp Development 5.6. Dialogs
Thanks fixed in 2.8
Chris M
Chris M
06 Jun 2019 04:50 - 06 Jun 2019 04:53 #136007
by partec
Replied by partec on topic Documents 2.8 - QTvcp Libraries modules 2. INFO
Thanks, I hope it is ok to put some news in here? Found
2. INFO
IINFO is a library to collect and filters data from the INI file.
The available data and defaults:
INFO
2. INFO
INFO
Last edit: 06 Jun 2019 04:53 by partec.
06 Jun 2019 05:36 #136010
by pl7i92
Replied by pl7i92 on topic rem em ber - in Document QTvcp Development 5.6. Dialogs
www.linuxcnc.org/docs/devel/html/gui/qtvcp_libraries.html
i think the tread is referring on this documentation
in the User interfaces there is no QTpyvcp interface on this time
is it just a screen over gscreen i guess
or will it be a own interface at one time
06 Jun 2019 08:12 - 06 Jun 2019 08:18 #136016
by partec
Replied by partec on topic Documents2.8 - QTvcp Lybrary modules 2. INFO
Hi pl7i92 sorry - reading and studying a lot of QtPyVCP documents at this time, I only found some spelling to be corrected, I hope it is ok to put this here in some reply?
in Documents 2.8 - QTvcp Lybrary modules
2. INFO
IINFO spelling should be corrected to INFO
2. INFO
Last edit: 06 Jun 2019 08:18 by partec.
07 Jun 2019 02:45 #136159
QtPyVCP and Qtvcp are two different projects.
Qtvcp is included in linuxcnc - QtPyVCP is a separate project, to be used with linuxcnc.
There are several experimental Qtvcp screen samples included so far:
linuxcnc.org/docs/devel/html/gui/qtvcp.html
They surely need polish - I build them to test building/programming ideas.
I'm not great at building pretty screens but I find - in time people give back great screens to the project.
(or this seems to be the case with Gscreen - also my project)
Qtvcp is separate from Gscreen but it's building/programming principles are similar.
any feedback - or code or spelling corrections is fine to post here.
(In the case of substantial code - a GIT patch or github pull request in nicer for me)
Chris M
Chris M
08 Jun 2019 01:54 #136275
Thank you .
08 Jun 2019 15:21 #136298
by partec
Replied by partec on topic rem em ber - in Document QTvcp Development 5.6. Dialogs
08 Jun 2019 16:59 #136299
Moderators: HansU
Time to create page: 0.173 seconds
