rtapi -- uspace -- "Using POSIX non-realtime"
21 Mar 2021 20:21 #203152
by V-max
Replied by V-max on topic rtapi -- uspace -- "Using POSIX non-realtime"
I have the same problem in a: Debian 10 4.19.0-14-rt-amd64 kernel.
Where can I check the last patch available?
Thanks a lot!
Thanks a lot!
21 Mar 2021 23:40 #203173
Replied by andypugh on topic rtapi -- uspace -- "Using POSIX non-realtime"
Are you sure that you have the same issue as this thread is discussing?
Did you compile the RT kernel yourself? (And, if so,. why?)
Did you compile linuxCNC yourself? (and, if so, why?)
What does uname -a say?
22 Mar 2021 17:56 #203270
by V-max
Hi Andy, Thaks for reply!
Are you sure that you have the same issue as this thread is discussing? /quote]
I'm a beginner and have this one:
"Failed to get reference clock time: Input/output error
task: 66304 cycles, min=0.000047, max=0.044388, avg=0.001064, 2 latency excursions (> 10x expected cycle time of 0.001000s)
Note: Using POSIX non-realtime
avc@avc:~/LinuxCncRip/scripts$ "
Firstly I tried to install:
"LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT ISO"
from the main page of download, but I had to install the headers and I wasn't able to find the headers for the kernel of this versión and installed the newer ones.
I'm trying to install EtherCAT Hal driver and a RIP installation is needed.
avc@avc:~$ uname -a
Linux avc 4.19.0-14-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.171-2 (2021-01-30) x86_64 GNU/Linux
avc@avc:~$
Thanks a lot!!
23 Mar 2021 00:40 #203323
In that case it does sound like you forgot
./configure --with-realtime=uspace
23 Mar 2021 19:05 #203418
by V-max
Hi andy
I have found a text file with the terminal out from when I did it.
Itś more, I had to do several times due to other problems and the first ones I had to apply:
configure --with-realtime=uspace --enable-non-distributable=yes
Is it the Kernel right?
V-max
V-max
23 Mar 2021 22:44 #203455
It is likely that the underlying problem is that you did "sudo make" so the ownership of you RIP install is wrong.
It should be
make
sudo make setuid
I would suggest cleaning up and trying again.
sudo make clean
make clean
./autogen.sh
It should be
make
sudo make setuid
sudo make clean
make clean
./autogen.sh
24 Mar 2021 22:00 #203551
by V-max
Hi Andy
Done but...
During the first try to start Linuxcnc there is not Posix note.
I do chmod 777 to rtapi_app and appear again the Posix note.
Thanks.
Done but...
Thanks.
26 Mar 2021 11:31 #203693
by thang
Replied by thang on topic rtapi -- uspace -- "Using POSIX non-realtime"
seem you missed command "sudo make setuid" after make lcnc
27 Mar 2021 21:53 #203843
You should not need to chmod anything.
"sudo make setuid" changes some permissions, but that is all that should be changed, and you should use the script, not do it by hand.
01 Apr 2021 09:08 #204376
by V-max
Hi andy
Thanks a lot for your help and sorry for the delay, I'm in a hurry lately.
I did CHMOD because I had permission problems:
avc@avc:~/LinuxCncRip/src$ sudo make setuid
chown root ../bin/rtapi_app
chmod 4750 ../bin/rtapi_app
chown root ../bin/linuxcnc_module_helper
chmod 4750 ../bin/linuxcnc_module_helper
avc@avc:~/LinuxCncRip/src$ cd ..
avc@avc:~/LinuxCncRip$ cd scripts/
avc@avc:~/LinuxCncRip/scripts$ . ./rip-environment
avc@avc:~/LinuxCncRip/scripts$ linuxcnc
LINUXCNC - 2.8.1
Machine configuration directory is '/home/avc/linuxcnc/configs/Maquina_ethercat'
Machine configuration file is 'maquinaEthercat.ini'
Starting LinuxCNC...
Found file(REL): ./maquinaEthercat.hal
./maquinaEthercat.hal:6: execv(/home/avc/LinuxCncRip/bin/rtapi_app): Permission denied
./maquinaEthercat.hal:6: waitpid failed /home/avc/LinuxCncRip/bin/rtapi_app trivkins
./maquinaEthercat.hal:6: /home/avc/LinuxCncRip/bin/rtapi_app exited without becoming ready
./maquinaEthercat.hal:6: insmod for trivkins failed, returned -1
/home/avc/LinuxCncRip/scripts/realtime: line 176: /home/avc/LinuxCncRip/bin/rtapi_app: Permission denied
LinuxCNC terminated with an error. You can find more information in the log:
/home/avc/linuxcnc_debug.txt
and
/home/avc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
avc@avc:~/LinuxCncRip/scripts$ cd ..
avc@avc:~/LinuxCncRip$ cd bin/
avc@avc:~/LinuxCncRip/bin$ sudo chmod 777 rtapi_app
avc@avc:~/LinuxCncRip/bin$ cd ..
LINUXCNC - 2.8.1
LINUXCNC - 2.8.1
and
LINUXCNC - 2.8.1
Time to create page: 0.172 seconds
