Linuxcnc error
- chelseafan
It seems to coincidental, it must need some kind of installing/compiling ect that iocontrol file because as I've said before All of the wiring seems good so I don't believe inputs aren't there.
Where would I type them lines of command would it be in a terminal and do I have to navigate with cd to a certain folder first ?
- Thank you received: 4107
forum.linuxcnc.org/9-installing-linuxcnc...-or-deb?limitstart=0
It starts from ground zero but you already have the OS installed so pick up on it where they start to build LinuxCNC
- chelseafan
- chelseafan
- chelseafan
any ideas
- chelseafan
ive attached the two files in text format as it wouldnt let me upload otherwise. in the submakefile it mentions emc and making it = io, io-orac, io-triac. io is the defualt setting. well i changed that a while ago from io-orac to io due to an error saying it can not load emc io-orac. so possibly this is my issue and i need to go back and fix this issue?
It looks like your missing pin is created in the
////////// NEW SECTION// currenttool
retval = hal_pin_s32_newf(HAL_IN, &(iocontrol_data->currenttool), comp_id,
"iocontrol.%d.currenttool", n);So the long and the short of it is that the pin will never exist unless the C code is compiled.I would also expect that it needs to be renamed to IoControl.cc but keep a backup of the original of that name so you can fall back.
Once you do that, use make to compile linuxcnc and halcompile to make your component and it will probably work.
- ArcEye
- Thank you received: 240
Otherwise the required mechanism for setting the initial tool number does not exist.
You can either build the toolchanger component in the source tree or seperately with comp (halcompile)
The component and modified iocontrol were written quite a few years ago for 2.5 or 2.6. If anything has changed with iocontrol since, that modified component might need updating, but it should just work.
I have never seen the lathe and only communicated online regards it.
I have not used linuxcnc for 3 years and have no further info regards this.
- chelseafan
i didnt actually get the machine to jog as to be honest i had no idea what to do when linuxcnc opened so ive started to read up on that now.
as for this last error. im assuning i have it installed. it was there on the pc when i got it under application/cnc. and i can only assume cncbasher knew what he was doing and did a rip install. am i able to check this somehow?
ive already tried what you suggested and changed the name of the new file to iocontrol.cc and this didnt work it wouldnt do a make and wanted to know where the file iocontrol-orac.cc was. from what i could see looking around linuxcnc when it loaded was that the machine thinks its at tool zero. and inputs 16,17,18 are my inputs for this. all these inputs are at 10volts, from abit of reading i believe two of these are used with a truth table to determine the tool and the third is for reversing the motor back onto its stop.
i think from comparing the standard file thats in the wiki that arceye did to mine cncbasher has done modifications over the years. these should be right as he was suppose to of run the machine before i got it.
im not really sure to be honest about this line ive commented out and if it will stop the toolchanger from working ill post it up when i can open the hal file properly.
- ArcEye
If you read the header of the Submakefile, it tells you what is going on
* # Amended 23082014 # ArcEye # # Add specific iocontrol components for Orac and Triac toolchangers # # Select the relevant io in the ini file # # [EMCIO] # EMCIO = io-triac (io-orac, or io for default) # #
IOSRCS := emc/iotask/ioControl.cc emc/rs274ngc/tool_parse.cc IOV2SRCS := emc/iotask/ioControl_v2.cc emc/rs274ngc/tool_parse.cc IOVORACSRCS := emc/iotask/ioControl_orac.cc emc/rs274ngc/tool_parse.cc IOVTRIACSRCS := emc/iotask/ioControl_triac.cc emc/rs274ngc/tool_parse.cc
USERSRCS += $(IOSRCS) $(IOV2SRCS) $(IOVORACSRCS) $(IOVTRIACSRCS)
../bin/io: $(call TOOBJS, $(IOSRCS)) ../lib/liblinuxcnc.a ../lib/libnml.so.0 ../lib/liblinuxcnchal.so.0 ../lib/liblinuxcncini.so.0 $(ECHO) Linking $(notdir $@) @$(CXX) $(LDFLAGS) -o $@ $^
../bin/iov2: $(call TOOBJS, $(IOV2SRCS)) ../lib/liblinuxcnc.a ../lib/libnml.so.0 ../lib/liblinuxcnchal.so.0 ../lib/liblinuxcncini.so.0 $(ECHO) Linking $(notdir $@) @$(CXX) $(LDFLAGS) -o $@ $^
../bin/io-orac: $(call TOOBJS, $(IOVORACSRCS)) ../lib/liblinuxcnc.a ../lib/libnml.so.0 ../lib/liblinuxcnchal.so.0 ../lib/liblinuxcncini.so.0 $(ECHO) Linking $(notdir $@) @$(CXX) $(LDFLAGS) -o $@ $^
../bin/io-triac: $(call TOOBJS, $(IOVTRIACSRCS)) ../lib/liblinuxcnc.a ../lib/libnml.so.0 ../lib/liblinuxcnchal.so.0 ../lib/liblinuxcncini.so.0 $(ECHO) Linking $(notdir $@) @$(CXX) $(LDFLAGS) -o $@ $^
TARGETS += ../bin/io ../bin/iov2 ../bin/io-orac ../bin/io-triac4 different versions of iocontrol are built and you select which one you want from the ini file
@cncbasher used the same computer for several machines, which is why I set up the build so that he had all the different versions available, just needed to specify which in the config.
I think you just need to get to know linuxcnc for now.
The tool number initialisation can be brought back in when you have more of a clue what you are doing.
