Spindle encoder wiring check
10 Nov 2017 11:06 #101594
by timmert
Replied by timmert on topic Spindle encoder wiring check
I have an index and 360ppr.
What do you recommend to use rigid tapping?
Sorry my knowledge about electronics is limited.
10 Nov 2017 14:32 #101607
Replied by andypugh on topic Spindle encoder wiring check
Can you re-state the current question? I have rather lost the thread here, even after reading back from the beginning.
23 Nov 2017 10:39 #102253
by timmert
I'm using the starter encoder that was installed on my lathe
This is a encoder with an index and 150ppr.
This should be enough for threading.
But I want to do rigid tapping.
So I will need a quadrature encoder.
The current encoder is connected with a toothed belt to the spindle.
08 Dec 2017 19:12 #102789
by timmert
This should work I guess?
A and B channel
And Z for Index
5-24V
www.aliexpress.com/item/Incremental-Rota...b04&rmStoreLevelAB=0
A and B channel
And Z for Index
5-24V
08 Dec 2017 20:44 #102796
Replied by PCW on topic Spindle encoder wiring check
That's an open collector interface encoder
It should be OK but if you have differential inputs, a E6B2-CWZ1X would be better
Also 2000 PPR is too high resolution for parallel port reading at more than a few hundred RPM
08 Dec 2017 20:52 #102797
by timmert
What's a good PPR?
This one is 1024PPR. The E6B2-CWZ1X isn't open?
www.aliexpress.com/item/1pcs-E6B2-CWZ1X-...f76&rmStoreLevelAB=0
09 Dec 2017 15:14 #102826
The maximum resolution (PPR) you can use depends on your hardware
What hardware are you using?
09 Dec 2017 17:04 #102830
by timmert
I use a 7i76/5i25
09 Dec 2017 18:06 #102835
OK so you can pretty much use any resolution encoder
Encoders with differential (line driver) outputs like the E6B2-CWZ1X
will have better noise immunity than TTL or open collector types
The following user(s) said Thank You: timmert
09 Dec 2017 19:08 #102837
by timmert
Thanks for the information PCW
I ordered the 2500PPR E6B2-CWZ1X
Time to create page: 0.097 seconds
