Gantry machine progress
12 Aug 2017 16:55 #97388
by Yannis
Replied by Yannis on topic Gantry machine progres
the homing of the machine is done with no physical limit and limit switch hooked up
since
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
HOME_IGNORE_LIMITS = yes
since
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
12 Aug 2017 17:09 #97391
by Clive S
Replied by Clive S on topic Gantry machine progres
I don't see it as the same as MIN_LIMIT = -0.01 MAX_LIMIT = 1500.0 is missing from the first YMAX_VELOCITY = 5000
MAX_ACCELERATION = 250.0
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
and are the same
The following user(s) said Thank You: Yannis
12 Aug 2017 18:50 #97392
There _must_ be only one [AXIS_Y] section. And it must contain the axis limits.
Replied by andypugh on topic Gantry machine progres
and are the same
12 Aug 2017 19:24 #97393
by Yannis
i saw this section of the INI file
ENCODER_SCALE = 800
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
HOME_OFFSET = 5.0
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
ENCODER_SCALE = 800
OUTPUT_SCALE = 10
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
HOME_OFFSET = 5.0
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
12 Aug 2017 19:28 #97394
by Yannis
andypugh replied
the right think to do is to have the [AXIS_Y] in Joint 1 or Joint 2?
12 Aug 2017 19:29 #97395
Joint limits and axis limits are not always the same thing.
(they have the same numbers, though, in your case)
Just delete the first [AXIS_Y] section that doesn't contain the Y axis limits.
12 Aug 2017 19:30 #97396
Neither. [AXIS_Y] is the [AXIS_Y] section. It could be anywhere in the INI file, but you should only have one of them.
12 Aug 2017 19:51 #97398
by Yannis
i have one more thing to ask
in some test i use the Touch button or the Touch off button for the z axis and then in the offset tab i write the value 50
the result of that is when i open the linuxcnc i have in the display of the z axis 50 (you can see that in the previous screen shots)
how can i change this value?(my z limits are -280 to0.1)
15 Aug 2017 17:00 #97523
You need to understand the difference between machine coordinates and work coordinates. The "50" is work coordinates.
If you switch the view to "absolute" (or "machine", depending on the GUI) you will see that you are still working in a -280 to 0.1 range.
16 Aug 2017 16:07 #97584
by Yannis
hi again
i try to configure the spindle output and the home limit inputs with no success in the hal file
# external input signals
# --- ESTOP-EXT ---
net estop-ext <= hm2_5i25.0.7i77.0.0.input-00
# --- HOME-X ---
net home-x <= hm2_5i25.0.7i77.0.0.input-01
# --- BOTH-X ---
net both-x <= hm2_5i25.0.7i77.0.0.input-02
# --- HOME-Y ---
net home-y <= hm2_5i25.0.7i77.0.0.input-03
# --- BOTH-Y ---
net both-y <= hm2_5i25.0.7i77.0.0.input-04
# --- HOME-Y1 ---
net home-y1 <= hm2_5i25.0.7i77.0.0.input-05
# --- BOTH-Z ---
net both-z <= hm2_5i25.0.7i77.0.0.input-07
# --- HOME-Z ---
net home-z <= hm2_5i25.0.7i77.0.0.input-08
# --- HOME-C ---
net home-c <= hm2_5i25.0.7i77.0.0.input-09
do i have to change anything else??
# --- ESTOP-EXT ---
# --- HOME-X ---
# --- BOTH-X ---
# --- HOME-Y ---
# --- BOTH-Y ---
# --- HOME-Y1 ---
# --- BOTH-Z ---
# --- HOME-Z ---
# --- HOME-C ---
Time to create page: 0.164 seconds
