Gantry machine progress
25 Sep 2017 06:22 #99392
by Yannis
Replied by Yannis on topic Gantry machine progress
As i see you are very good in math( i m not)
but as i measure with chronometer the time for full acceleration of the 3 ton bridge i find that it needs 1.79 seconds to reach the 15000
so maybe there are some mixed up in the units or something
25 Sep 2017 11:39 #99399
by scubawarm
Replied by scubawarm on topic Gantry machine progress
If that is the case...
Your small acceleration numbers are being ignored.
- Thank you received: 1369
25 Sep 2017 13:23 #99403
To accelerate from 0 to 15000mm/s in 1.79 seconds would require an acceleration rate of 8380mm/s^2. Significantly more than the 350mm/s^2 in your config file. (Something doesn't add up.)
Replied by Todd Zuercher on topic Gantry machine progress
25 Sep 2017 13:28 - 25 Sep 2017 13:29 #99404
Duh, and here it is you said 15000 (but didn't specify the units.) That was 15000 mm/min wasn't it. And that would be 250mm/s (all the units in the ini file are in units/sec not units/min). 250/1.79 = 140mm/s^2 (within the limits specified in your ini file.)
Last edit: 25 Sep 2017 13:29 by Todd Zuercher.
The following user(s) said Thank You: Yannis
29 Sep 2017 11:57 #99606
by Yannis
Hi
That was 15000 mm/min wasn't it?
Yes my units is mm/min
The G64 settings are working great
