2.7.11 kernel?
02 Aug 2017 02:44 #96874
by 64dodge
2.7.11 kernel? was created by 64dodge
I upgraded ubuntu 10.04 with linuxcnc 2.5 to 2.6 to 2.7 but when I uname -r to check kernel it says 2.6.32-122.
Is this right? Theres no place in grub other than this kernel to boot to.
I have been using this drive checking latency in many old pc's upgrading as I go.
Latency test works in about half (the newer half but still old 1.5-2.5ghz) but 1ghz and slower
ubuntu works fine but latency test or lcnc wont run.
Second question can 8.04 be upgraded to lcnc 2.6 or 2.7?
Tim
Tim
- Thank you received: 1369
02 Aug 2017 03:42 #96875
Replied by Todd Zuercher on topic 2.7.11 kernel?
That is the correct kernel version number for Lucid, but it should say 2.6.32-122-rtai. The kernel version number has nothing to do with the Linuxcnc version number.
No, Linuxcnc 2.6+ will not run on 8.04.
02 Aug 2017 20:35 #96939
Grub sometimes hides the RTAI kernel in a "previous kernels" sub-folder.
But, updating LinuxCNC shouldn't cause any kernel changes, assuming you used the package manager rather than a livedCD reinstall?
Replied by andypugh on topic 2.7.11 kernel?
03 Aug 2017 02:19 #96954
by 64dodge
Replied by 64dodge on topic 2.7.11 kernel?
Thanks to you both Todd & Andy. The difference in software and kernel version had me very confused. Yes it did have rtai, just forgot to type it in post. I upgraded with package manager all went well. There were no sub folders in grub only this kernel to pick from.
Thanks again for setting me straight.
Time to create page: 0.276 seconds
