G0 movement gouges part
09 Oct 2020 21:34 #185510
by mydani
G0 movement gouges part was created by mydani
Hi guys,
I wonder what's going on with my G0 movement.
My mill is at Z-11, then 2 G0 statements come after each other.
G0 Z3
X... Y..
What I can see is that x/y coordinates are changing way before Z reaches 3 - it starts so early, before Z0! so it gouges the part.
Happens even when rapid feed rate is reduced to 1%. I can of course change the post to use G1 to go to safe zone.
But I'd rather understsand why G0 behaves like this. I heard of machines who will do unsynchronized motion, but this should be sth different.
Who can explain?
Regards,
Daniel
G0 Z3
X... Y..
Who can explain?
Regards,
Daniel
10 Oct 2020 00:05 #185520
by phillc54
Replied by phillc54 on topic G0 movement gouges part
10 Oct 2020 10:01 #185580
by mydani
Replied by mydani on topic G0 movement gouges part
No sir, Checked the code and no g64 there. And the standard when powered up is g64 p0.002.
Regards Daniel
Regards Daniel
10 Oct 2020 10:06 #185582
by phillc54
I think it would be worthwhile to put it in your G-Code file.
Do you have it set in the ini file?
- Mike_Eitel
- Thank you received: 185
10 Oct 2020 11:22 #185592
by Mike_Eitel
Replied by Mike_Eitel on topic G0 movement gouges part
Have you tried to repeat these lines very slow and see when this (i think diagonal) movement happens...
Mike
Mike
21 Jan 2021 19:29 #196132
by mydani
Sorry it took so long, today I found another perfect example (forgot to use feed instead of g0)...
There you go:
even though the code says to move to Z4, then X/Y, the machin stops before reaching Z4 and only continues to move in Z when I execture the next step which is a X/Y movement.
You can see it clearly in the video.
Looking forward to opinions!!
Regards,
Daniel
There you go:
Regards,
Daniel
- Thank you received: 5938
21 Jan 2021 21:52 #196151
Replied by tommylight on topic G0 movement gouges part
I can reproduce this behaviour on a sim, build 3397 of the master/scratch, the Z height stops at incorrect values even with the use of G64 P0.1. Also notice the radii created after a Z retract and moving to another position. The cut depth is set at 2mm but it stops short and waits till the next G1 move, and when going up that is even more off .
See attached video:
See attached video:
22 Jan 2021 01:56 #196174
by cakeslob
Replied by cakeslob on topic G0 movement gouges part
honestly, i just wanted to play with the colour changing toolpath thing that recently was added by cmorley (thanks for the help) , I am getting similar values to what tommy is getting in regards z height, ( mine are .5mm and 1.879mm), but the entry on the letter c is what caught my attention,
this is G64 P0.05
this is just G64
this is both
the entry into the arc on the letter c is better(?) with G64, than on g64 P 0.05, all the others are seemingly predictable, im going to assume, based on the line legment length, for G64, but there is no blend on when entering on an arc, while p0.05 stays uniform the entire time. I dont know what it means, or if its a problem, I just found it interesting. I usually program an overlap on a contour toolpath anyways
this one just for kicks, colours reversed on this one
on an unrelated note, do you ever try to rotate/pan screenshots of axis, and wonder why its not working...
this is G64 P0.05
this is just G64
this is both
22 Jan 2021 05:09 #196178
Replied by PCW on topic G0 movement gouges part
Did you try G64 P .002 Q.002
22 Jan 2021 17:20 #196245
As a side note, i did use P and Q all the time when the new trajectory planner was introduced to 2.7, but since 2.8 never noticed it is required.
Back in 5
Will check that promptly and report back.Did you try G64 P .002 Q.002
Back in 5
Time to create page: 0.239 seconds
