Machine Stutter / Notching Phenomenon
01 Dec 2020 19:27 #190789
by AlexDoran
Replied by AlexDoran on topic Machine Stutter / Notching Phenomenon
Hi guys, I changed the timings as suggested but I still am getting this, I think it is the machine actually losing steps. Is there any way I can view latency in real time? Does HAL Meter offer this?
If I am losing steps, where do I start in rectifying it? New computer? I see people using much lower spec pcs running fine.
I have another video, I ran at a higher speed and the stutter is slightly easier to pick up, though speed doesn't seem to be Influencing it at all, infarct I would say it's almost smoother at higher speeds.
01 Dec 2020 20:14 - 01 Dec 2020 20:55 #190793
Replied by PCW on topic Machine Stutter / Notching Phenomenon
You can plot the base thread time with halscope
or watch the base thread tmax value with halmeter or halshow
Have you tried say moving windows around on
the screen to see if you get more "thumps"?
This would be diagnostic of latency issues.
Last edit: 01 Dec 2020 20:55 by PCW.
01 Dec 2020 20:57 #190796
by AlexDoran
Hi and thanks for your reply.
I have not, I will try these in the morning when I'm back at the machine thank you.
02 Dec 2020 17:41 - 02 Dec 2020 17:45 #190887
by AlexDoran
Hi again,
So I tried your suggestions today.
Whilst running gcode I can see my base thread time hovers around 33k. It occasionally peaks to ~40k
In my .ini I have base as 50k and servo as 100k.
Is this correct??
Currently I'm watching latency test. With like 20 Firefox windows open and dragging one around I'm at around ~33k Base Thread Max Jitter and 26k Servo Thread.
However my last interval for servo is pinned at like 999999.. is that right?!
Is this correct??
Last edit: 02 Dec 2020 17:45 by AlexDoran.
02 Dec 2020 17:49 - 02 Dec 2020 17:50 #190889
I think your servo thread is too fast, normally this should be set to 1ms (1000000 ns)
Last edit: 02 Dec 2020 17:50 by PCW.
02 Dec 2020 17:53 - 02 Dec 2020 18:02 #190890
by AlexDoran
That's what it's set to, shall I increase it more?
Also I checked repeatability with a dial indicator, it's definatley losing steps.
Guess I will try another PC, maybe it's the BoB?
Last edit: 02 Dec 2020 18:02 by AlexDoran.
02 Dec 2020 18:20 #190892
is it 100K or 1000K? (should be 1000K)
02 Dec 2020 18:28 #190893
by AlexDoran
It was 100k, but just tried 1000k and it's the same.
I'm leaning towards maybe a faulty BoB. I just powered everything up and I noticed the 5v LED from USB Power (I have it on a old iPhone mains usb charger - 5v) and noticed it dwindling slightly. Could this be an indication of problems? It has a steady 5v however.
02 Dec 2020 18:34 - 02 Dec 2020 18:53 #190894
Certainly 5V power issues could cause this type of a problem
Do you have a voltmeter to measure the 5V at the BOB?
Note that the servo thread should remain at 1000,000 ns
Last edit: 02 Dec 2020 18:53 by PCW.
02 Dec 2020 18:44 - 02 Dec 2020 18:58 #190896
by AlexDoran
Hi again,
Yes 5v at the BoB is consistent, i actually pushed the LED with my finger and it corrected so i now suspect a dry solder there lol..........
Now to throw another spanner in the works- i can run the stepconf axis test as fast as i want and the machine moves BUTTERY SMOOTH, no stutters or lost steps. This gives me hope that my setup is ok, but also confuses me as to how im supposed to fix it lol.
Thanks again for helping me i really appreciate it.,
EDIT:
In stepconf i had:
20000
20000
40000
40000
Base Thread 50000
Edit:
Tested those same values in both Axis and Gmocappy and the lost steps is still there
EDIT:
In stepconf i had:
20000
20000
40000
40000
Base Thread 50000
Edit:
Last edit: 02 Dec 2020 18:58 by AlexDoran.
Time to create page: 0.096 seconds
