Testing a Stepper Motor from a live image
- Creative25
21 Dec 2020 09:43 #192614
by Creative25
Testing a Stepper Motor from a live image was created by Creative25
Good Morning.
I am planning to build a plasma Cutter but parts are coming in slowly.
For now I would like to thest if my stepper motors are fine and test Acceleration etc.
My hardware is a Macbook pro with a live image. Linuxcnc 2.8 ( I do not want to install Linuxcnc on this computer just want to test the Stepper motors.
Mesa 7i76e board
Stepper motor drivers TB 6600
Stepper motors Nema 23 3Nm
Problem I can not save configurations with the Live image.
Is there a way to test the Stepper motors without installing linuxcnc on the Hard Drive?
Or do I first have to get another computer. Where I can install linuxcnc?
Mesa 7i76e board
- Thank you received: 5946
21 Dec 2020 11:54 #192624
Replied by tommylight on topic Testing a Stepper Motor from a live image
You can save configs to another USB, if there are free ports on the Mac!
Live image is a fully functional one, so everything works as on a normal install, just do not leave blank spaces on the file and folder names for the config, and the config can be saved and used from anywhere on the PC or USB, or even over the network, but that needs a bit of tinkering.
The following user(s) said Thank You: Creative25
- Creative25
21 Dec 2020 12:02 #192626
by Creative25
Replied by Creative25 on topic Testing a Stepper Motor from a live image
Thanks for the Assurance that the live image is fully functional. Yes I have an additional Usb port so saving a file to an additional Usb drive is an option Unfortunateley on version 2.8 there are noe smple files included for 7i76e
Is there anyone who has a config file for the 7i76e board. Even a file for a lathe or a Mill will do the only thing I want to do for now is test the stepper motors.
21 Dec 2020 12:41 #192636
Use pncconf from the menu, it is fully supported so it takes under 5 minutes to have a working config normally.
- Creative25
21 Dec 2020 13:51 #192646
by Creative25
Do I need to connect my Mesa board before starting configuration?
21 Dec 2020 14:12 #192649
Making a config does not require have the board connected and powered, running the config does.
Or you can use many SIM configs with no hardware attached.
- Creative25
21 Dec 2020 15:42 - 21 Dec 2020 15:45 #192661
by Creative25
So I made a quick config file. Not sure If I did it right.
I ohly filled in the info about the XYZA axis.
Left the pages about encoder and Io ports empty.
But i keep getting error messages and Linuxcnc quits.
What Am I missing?
See Attachments.
What Am I missing?
See Attachments.
Last edit: 21 Dec 2020 15:45 by Creative25.
21 Dec 2020 18:19 #192680
When LinuxCNC errors out it opens a window with info about why it did not start, and on the bottom of that window there is the "create report file" button, click on that then upload the file created by it .
- Creative25
22 Dec 2020 00:14 #192757
by Creative25
That is exactly what I did.
But then it did not allow me to attach it because the file extension was not allowed so I changed it to txt. And it was allowing me to upload the file.
What would be the correct way of Uploading the report file?
- Creative25
22 Dec 2020 06:50 - 22 Dec 2020 06:53 #192786
by Creative25
Looks like I tried to Upload the wrong file.
Hope this is the correct ones.
Last edit: 22 Dec 2020 06:53 by Creative25.
Time to create page: 0.195 seconds
