Testing a Stepper Motor from a live image
- Thank you received: 5946
22 Dec 2020 10:18 #192797
Replied by tommylight on topic Testing a Stepper Motor from a live image
The networking is not set up so it can not find the Mesa card.
Check the LinuxCNC documents about networking setup.
- Creative25
22 Dec 2020 10:35 #192800
by Creative25
Replied by Creative25 on topic Testing a Stepper Motor from a live image
Thanks I figured ist out had to set up the network manually.
I can ping the Board, and also Linuxcnc starts corrrectly.
But still there is a problem I can not jog.
If I am pressing the buttons of any axle the numbers change but the stepper motors dont move.
What could be missing?
Is there something wrong with the config file, or
do I first need to flush the firmware in my mesa board?
22 Dec 2020 11:28 #192802
Edit the ini file in the config folder, for each axis/joint set these values:
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
- Creative25
22 Dec 2020 15:48 #192826
by Creative25
Unfortunateley that did not solve the Problem.
I measured and found that the correct signals come out of the Mesa board.
If I Press x- it gets 5v on the Direction pin.
On the Pulse pin I also get a voltage that depends on the Settings for jogging speed.
So basically there must be something wrong with the Connectors for to the Stepper drivers.
I put
5+ on enable +
And Ground on the enable -
Plus I connected all the Pulse and Direction pins.
The positive and the negative ones.
Is this Correct?
Where can I find good info about connecting a steper driver to a Mesa 7i76e Board?
I put
5+ on enable +
Is this Correct?
22 Dec 2020 15:53 #192829
Do not connect the enable pins, can be done later.
When powered the motor should lock in place and can not be easily moved by hand.
- Creative25
22 Dec 2020 17:03 #192836
by Creative25
Just had a good look at the stepper drivers manual.
I thought the enable pins turn the drive on and off.
In a sense yes but just the opposite way around.
So basically if you Power the enable pins it overrides all the other signals from the Mesa board.
Maybe it is time for a good laugh.
I will disconnecct those two wires, and see what happens.
22 Dec 2020 18:36 #192844
Strangely it caught on.....
Another Chinese gift to the world, having the enable active by default !Maybe it is time for a good laugh.
- Thank you received: 1370
22 Dec 2020 19:20 #192848
Replied by Todd Zuercher on topic Testing a Stepper Motor from a live image
That arrangement seems to mostly be the norm for most stepper drives. (Our very old and very USA made uni-polar drives from Anaheim Automation also follow that convention.) And if you think about it an enable switch for a step motor is rather pointless anyway. But there are rare occasions where a disable might be useful.
22 Dec 2020 20:00 #192856
I thought was a sneaky trick to waste hours of ones time on your first CNC build....
Replied by rodw on topic Testing a Stepper Motor from a live image
22 Dec 2020 21:46 #192874
LOL @ Rod,
And thank you Todd for enlightening me, i must have worked with over 100 types of stepper drives, mostly yanked from old industrial machines and those always require the enable pin to be grounded to work. The first encounter of the "no enable = enabled" was with some leadshine 742 drives several years back.
