Can i use only two axis (X,Y) to a plasma projest?
12 Feb 2021 15:02 #198540
by Ekholm
Can i use only two axis (X,Y) to a plasma projest? was created by Ekholm
Hi!
Can i use only two asis (X,Y) for a plasma? I have a Mesa 7i96 card and used the pnfconf wizard. When folowing the wizard, i couldn´t configure the mesa card without entering a z-axis. Or should i use the lathe setup?
Is there any video guides of how linuxcnc interface works? I have only found configuration videos, i want hadeling videos
Thanks! /Andreas (from sweden)
12 Feb 2021 15:45 #198543
by Clive S
Have you seen this; forum.linuxcnc.org/plasmac/37234-plasmac-documentation
You need a Z axis with a plasma
The is also a 7i96 tool to help to get the base working : forum.linuxcnc.org/27-driver-boards/4109...nfiguration-tool-deb
Replied by Clive S on topic Can i use only two axis (X,Y) to a plasma projest?
Hi!
- Thank you received: 5932
12 Feb 2021 17:00 #198550
Replied by tommylight on topic Can i use only two axis (X,Y) to a plasma projest?
You can use X and Y only on a plasma, granted the table is very levelled and cutting thick flat material, but that never happens.
Still, a geared DC motor can be used with a double throw switch to control the Z axis manually, but that requires staring at the torch at all times.
12 Feb 2021 21:01 #198575
by Ekholm
Replied by Ekholm on topic Can i use only two axis (X,Y) to a plasma projest?
Thanks for the information about plasmac! I have ordered parts for a z-axis, but they have not arrived. So I wanted to test the x and y but couldn’t make it to work
12 Feb 2021 21:14 #198582
To test without cutting, use a switch wired to float switch or ohmic probe, and trigger it roughly when it should hit the material hold for a second then release, all this with the torch disabled in the GUI.
Of course, this is for open loop systems, so any stepper or servo system with step/dir control.
12 Feb 2021 22:56 #198604
by Clive S
Couldn't make what work.?
It might help to post the hal and ini files
Time to create page: 0.079 seconds
