7i96 Configuration Tool Deb
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
10 Jan 2021 13:58 - 23 Mar 2021 12:28 #194728 by BigJohnT
7i96 and 7i76e Configuration Tools was created by BigJohnT
Both tools have a deb to install them and a menu item gets added to the CNC menu. I try and make the Configuration Tools as easy to use as possible and don't force you to pick a type of machine. You can configure a single axis machine if that's what you need.
If you have any issues please open an issue.
7i96 Issue Tracker
7i76e Issue Tracker
JT
Last edit: 23 Mar 2021 12:28 by BigJohnT.
The following user(s) said Thank You: tommylight, Markyd
  • BigJohnT
  • Administrator
  • Administrator
10 Jan 2021 19:11 - 10 Jan 2021 19:12 #194753 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool Deb
I just finished adding two menu items Save Pins and Save Signals. These will get the pin and signal names and save them to a text file in your configuration directory. No more twiddling around in a terminal to get a list of all the pins and signals.
I'll push the .deb in the morning during free time... on metered time now.
JT
Last edit: 10 Jan 2021 19:12 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
12 Jan 2021 14:09 #195054 by BigJohnT
One of the many tools included with the 7i96 Configuration tool is the NIC speed test with which you can easily figure out if your CPU and NIC are fast enough for a Mesa Ethernet Card.
JT
  • BigJohnT
  • Administrator
  • Administrator
13 Jan 2021 12:41 #195209 by BigJohnT
On the Info tab you can find the information about the CPU and the NIC.
JT
  • BigJohnT
  • Administrator
  • Administrator
13 Jan 2021 12:43 #195210 by BigJohnT
On the Pins tab you can get the actual pin names, also note you can send the pin names and signal names to a text file from the File menu.
JT
  • BigJohnT
  • Administrator
  • Administrator
13 Jan 2021 12:51 #195211 by BigJohnT
Also on the pins tab you can see the terminal blocks and their function.
JT
  • BigJohnT
  • Administrator
  • Administrator
13 Jan 2021 12:52 #195212 by BigJohnT
On the PLC tab you can change the defaults for Classicladder.
JT
  • BigJohnT
  • Administrator
  • Administrator
13 Jan 2021 13:18 #195214 by BigJohnT
On the Options tab you can select various options.
JT
  • BigJohnT
  • Administrator
  • Administrator
13 Jan 2021 13:19 #195215 by BigJohnT
On the Outputs tab you can configure the outputs of course.
JT
  • BigJohnT
  • Administrator
  • Administrator
13 Jan 2021 13:21 #195216 by BigJohnT
On the Inputs tab you can configure the inputs
JT
Moderators: PCW, jmelson
Time to create page: 0.601 seconds
