- General
- General LinuxCNC Questions
- wiring & wizard setting for minimal working of simple normal closed limit switch
- Online
- Thank you received: 5945
24 Feb 2021 12:16 #199967
Replied by tommylight on topic wiring & wizard setting for minimal working of simple normal closed limit switch
I did see that, but you can not run a machine on a generic kernel, it must have RT or RTAI kernel for machine use.
If you see my above discussion in this thread only, I was using 2.8.1 in Ubuntu with generic kernel and everything was running well except limit switch.
24 Feb 2021 14:54 #199989
by suraj9735
Ok, That's fine, but what about the newmesa.zip file?
should I follow the instructions ( newmesa.zip )?
Replied by suraj9735 on topic wiring & wizard setting for minimal working of simple normal closed limit switch
24 Feb 2021 15:48 - 25 Feb 2021 07:19 #199993
Oh, so it looks like you need to upgrade to version 2.9 for your board to work.
Instructions on how to upgrade are here:
buildbot.linuxcnc.org/
Your repsitories will be:
[edit]
To use the mesa files you would need to download the linuxcnc source code and copy those files into the source folder and then you would need to build linuxcnc directly on your machine. While certainly possible for a linux newcommer it usually requires a fair bit of will power to get all the required dependencies installed. But after you master that you can do pretty much anything.
Replied by Aciera on topic wiring & wizard setting for minimal working of simple normal closed limit switch
deb http://buildbot.linuxcnc.org/ buster master-rtpreempt
deb-src http://buildbot.linuxcnc.org/ buster master-rtpreempt
[edit]
Last edit: 25 Feb 2021 07:19 by Aciera. Reason: My apologies as it apparently does work with 2.8.1
24 Feb 2021 20:42 #200023
Replied by PCW on topic wiring & wizard setting for minimal working of simple normal closed limit switch
newmesa.zip is obsolete, you should be fine with 2.8.1
- General
Time to create page: 0.135 seconds
