- General
- General LinuxCNC Questions
- Hardware Problem - Latency Test and Screen Freeze - Linuc CNC 10.04
11 Apr 2021 09:02 #205619
Yes, take a look at linuxcnc.org/docs/2.8/html/man/man9/debounce.9.html
Are you using the parallel port or some other hardware interface?
Replied by andypugh on topic Hardware Problem - Latency Test and Screen Freeze - Linuc CNC 10.04
Are there any options in LINUX CNC to changes the reaction time or to deactivate
the switches for dedicated situations where vibrations occur for example ?
12 Apr 2021 04:56 #205699
by JohannesL
Replied by JohannesL on topic Hardware Problem - Latency Test and Screen Freeze - Linuc CNC 10.04
Hello Andypugh,
thanks for your help. I am using an parallel port.
Yesterday I set up a machine configuration without limit switches.
But I wish would be to implement the "Debounce Filter "
How does it congrete work in Linux CNC ?
Normaly I define an time which will be count after high or low leven of an pin and afterwards the µC acepts the level and use it for the code so the limit switches
must be read out and after a short time period the level of the limit switches will be used as Hard Stop but not if the level is for very short time 1ms or less high....
Have a nice day and again thank you for your help.
12 Apr 2021 18:23 #205725
The way debounce works is that the component needs to see the same value at the input for as many thread cycles as the time parameter before changing state.
You can debounce in either the base thread or the servo thread, when there is a base thread.
- General
Time to create page: 0.163 seconds
