7i84 not working
- Thank you received: 5946
25 Mar 2021 11:45 #203603
Replied by tommylight on topic 7i84 not working
I can check it in Kosovo !Where is the 7i84? I can check it in the UK, or PCW could check it in the USA.
25 Mar 2021 14:12 #203619
by stegrg
Replied by stegrg on topic 7i84 not working
I have a secondary fully functional system utilizing a 5i25 + 7i76 setup. I tried to connect the 7i84 to the RS-422 port on the 7i76 card and I noticed that if I pull the TXA (Green/White) and/or the TXB (Green) wire out from the 7i52 connector, CR8 illuminates. If both are connected, CR8 will no illuminate. I don't know if this means anything but I thought I'd mention it. I also can't get any response from the 5i25+7i76 setup.
I'm located near Toronto, Canada. I think PCW is closest to me. (Thanks to Andypugh and Tommylight for reaching out)
25 Mar 2021 17:57 #203631
Replied by PCW on topic 7i84 not working
Probably best to to request an RMA from Mesa
Not worth sending back so they will just replace it
27 Mar 2021 21:48 #203842
Have you tried a different RJ45 cable? Maybe that one has a short in the connector or wire?
Replied by andypugh on topic 7i84 not working
27 Mar 2021 22:11 #203848
Also if you lose CR8 when you connect all interface pins, this could be a 5V power issue on the interface daughtercard (voltage collapses as soon as the 7I84 TX lines connect to termination)
29 Mar 2021 14:46 #204044
by stegrg
Yes, I checked continuity from the solder joints of the 7i84 RJ45 connector to the other end of the cable to make sure proper connections were made inside the jack and/or plug.
Time to create page: 0.530 seconds
