(Solved) 7i76 can only get one encoder
26 Mar 2021 13:44 #203708
by bevins
7i92_7i76x1dpl
Replied by bevins on topic (Solved) 7i76 can only get one encoder
Which firmware was it?
JT
7i92_7i76x1dpl
26 Mar 2021 13:57 - 26 Mar 2021 14:11 #203713
Replied by PCW on topic (Solved) 7i76 can only get one encoder
You probably only have 1 encoder enabled in your hal file
Last edit: 26 Mar 2021 14:11 by PCW.
26 Mar 2021 14:15 #203715
by bevins
I had the wrong bit file in the 7i92.
I tried to put solved in the topic but cannot. Solved it by putting the correct bit file in it.
- Thank you received: 5947
26 Mar 2021 17:10 #203734
Replied by tommylight on topic (Solved) 7i76 can only get one encoder
Done, thank you.
The following user(s) said Thank You: bevins
Time to create page: 0.135 seconds
