(Solved) 7i76 can only get one encoder
26 Mar 2021 10:07 - 26 Mar 2021 11:07 #203680
by bevins
(Solved) 7i76 can only get one encoder was created by bevins
Looking for second encoder.
If I put num_encoders=2 in the loadrt line then I get error.
This a firmware issue?
Last edit: 26 Mar 2021 11:07 by bevins.
26 Mar 2021 10:23 - 26 Mar 2021 10:29 #203682
by bevins
Replied by bevins on topic (Solved) 7i76 can only get one encoder
Loadrt line:This spits an error about the config.num_encoders=2 but only 1 available.
I think I have the correct firmware loaded. It shows the DPLL module which I think is what is needed for plasmac.
mesaflash readhmid
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=2 num_pwmgens=0 num_stepgens=4 sserial_port_0=200xxx"
mesaflash readhmid
Warning: Spoiler!
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData0 (Out)
8 11 IOPort SSerial 0 RXData0 (In)
9 12 IOPort SSerial 0 TXData1 (Out)
10 13 IOPort SSerial 0 RXData1 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
15 20 IOPort None
3 21 IOPort None
16 22 IOPort None
4 23 IOPort None
17 24 IOPort None
5 25 IOPort None
6 26 IOPort None
7 27 IOPort None
8 28 IOPort None
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
12 32 IOPort None
13 33 IOPort None
Last edit: 26 Mar 2021 10:29 by bevins.
- Thank you received: 5950
26 Mar 2021 10:29 #203683
Replied by tommylight on topic (Solved) 7i76 can only get one encoder
7i76 has only one normal encoder and 2 MPG encoders.
For MPG encoders to be usable the initialisation line in hal has to be set to mode 1 or 2 (not sure) but i do set it to mode 2 always as it also gets the 4 analogue inputs besides 2 MPG.
forum.linuxcnc.org/24-hal-components/385...e-7i76-mode-question
They should be visible as enc0 and enc1.
26 Mar 2021 10:30 #203684
by bevins
I have those, I am talking about the encoders for plasmac. those encoders are for pins 16,17 18,19 I think.
26 Mar 2021 10:35 #203685
by bevins
26 Mar 2021 10:42 #203686
Ok, you need the 2 encoder inputs for the THCAD so that requires the "PL" in the firmware name, not DPLL (dpll is timings function on a phase locked loop), pretty sure PCW made one.
The following user(s) said Thank You: bevins
26 Mar 2021 10:48 #203687
by bevins
There is only dpl in the 7i92.zip firmware..... Thats not the correct one?
26 Mar 2021 10:51 #203688
From your screenshot pretty sure it is not as the inputs should be shown as input A only, 3 of them.
26 Mar 2021 11:06 #203690
by bevins
I found firmware file that works now the encoder01 shows up.
Now on to ohmic hal file errors.
26 Mar 2021 12:59 #203703
by BigJohnT
Replied by BigJohnT on topic (Solved) 7i76 can only get one encoder
Which firmware was it?
JT
JT
Time to create page: 0.212 seconds
