Prime Weld Cut 60 THC wiring
05 Apr 2021 22:34 - 05 Apr 2021 22:35 #204976
by kevpsk8
Prime Weld Cut 60 THC wiring was created by kevpsk8
I am new to the CNC world and am trying to build my first table. I have a Mesa 7I96 board with the Mesa THCad-10. My plasma cutter is a Primeweld Cut 60 and has the option for 1/16th or 1/50th raw arc divided voltage. I am unsure which voltage will work best the the THCad-10. I do not have the machine fully wired and complete to test anything but I would like to be able to wire my cnc port into the correct terminals.
Last edit: 05 Apr 2021 22:35 by kevpsk8.
- robertspark
- Thank you received: 216
05 Apr 2021 23:01 #204981
by robertspark
Replied by robertspark on topic Prime Weld Cut 60 THC wiring
50:1 in my opinion
16:1 is too low a ratio for a thcad10
23 Apr 2021 16:28 #206879
by kevpsk8
Replied by kevpsk8 on topic Prime Weld Cut 60 THC wiring
I wired to 1:50 and I am getting -74 volts on the plasmac display. The THC does not seem to be working and goes into the VAD setting when cutting.
23 Apr 2021 23:06 #206897
You have an encoder scale wrong in hal to get -ve values
check the encode.n.velocity pin in halshow to see if its negative. Change the sign of your scale value to get it counting up.
Replied by rodw on topic Prime Weld Cut 60 THC wiring
04 May 2021 03:08 #207784
by kevpsk8
I entered the THCAD config in the HAL file per the plasmac user guide
setp hm2_7i96.0.encoder.00.scale -1
setp hm2_7i96.0.encoder.00.filter 1
setp hm2_7i96.0.encoder.00.counter-mode 1
This made it so plasmac was sensing the arc voltage and with using the THCAD calculator values the voltage would hover around 0. When I tried a test cut the value would go down to -4. Rod I am unsure on where to look for the value you are speaking about.
Thank you
Thank you
Time to create page: 0.187 seconds
