Building diy cnc
- davestreet
13 Apr 2021 11:42 #205775
by davestreet
Building diy cnc was created by davestreet
Hi
Just joined and would like to know if it is advisable to build diy cnc as my other endevours have failed this was using Mach3 software
could not get on with at all nothing worked
No problem building m\c but trying to run it from the software was a nightmare can you help?
Thanks Dave
Thanks Dave
13 Apr 2021 14:08 #205796
by bevins
This is a bit vague. Can we have more detailed info on what you want to do and info on your machine?
Replied by bevins on topic Building diy cnc
Hi
Thanks Dave
13 Apr 2021 21:57 #205829
Most folk agree that Mach3 is easier to get going than LinuxCNC.
But LinuxCNC is probably more adaptable, so if the problems were that your machine wasn't a good fit for LinuxCNC, then LinuxCNC might help.
Replied by andypugh on topic Building diy cnc
Time to create page: 0.137 seconds
