How to set up parallel port in Debian
- paulstenlund
19 Apr 2021 09:03 #206368
by paulstenlund
How to set up parallel port in Debian was created by paulstenlund
How do I set up my parallel card in Debian, its not seeing it. Is there a tutorial?
Paul
Paul
- Thank you received: 7417
19 Apr 2021 14:00 #206385
Replied by tommylight on topic How to set up parallel port in Debian
In a terminal:
sudo lspci -v
and
sudo dmesg | grep par
Post the results of those two lines here.
sudo lspci -v
and
- paulstenlund
20 Apr 2021 02:07 #206492
by paulstenlund
Replied by paulstenlund on topic How to set up parallel port in Debian
can't run cms term wants a passwor, login pw did''t work. How do I create admin - root pw now.
- paulstenlund
21 Apr 2021 01:40 #206599
by paulstenlund
OK reinstalled Debian now my terminal works great. ran the commands and i definitely have a parallel port, Why are my machine controls greyed out?
- Thank you received: 4642
21 Apr 2021 21:21 #206707
Replied by andypugh on topic How to set up parallel port in Debian
Firstly, you don't really need to set the port up with Debian. LinuxCNC uses its own driver, so you just need to tell LinuxCNC the port address.
Actually, you often don't even have to do that, telling LinuxCNC to connect to the first parallel port that it finds (index number 0) is typically enough.
Do you see the p-port with lspci? If you do then it probably isn't at the 0x738 address (which is typically a motherboard port)
Can you show the output of "lspci -vv" and "cat /proc/ioports"
- paulstenlund
21 Apr 2021 21:55 #206719
by paulstenlund
I can run the commands but don't know how to capture the output to a file
21 Apr 2021 22:03 #206722
You can select the text in a terminal and right click to copy it, then paste it here.
- Farmerted
27 May 2025 02:02 #329188
by Farmerted
Replied by Farmerted on topic How to set up parallel port in Debian
I’m having a similar issue, I’ve run the above commands and captured the output, would you be able to help? I know this thread is pretty old. Would it help to just paste the outputs or include as a file?
27 May 2025 08:23 #329202
- Farmerted
27 May 2025 14:15 #329221
by Farmerted
Thanks, I went through referenced thread, not sure I understood any of it.
I have an Asix Electronics Corporation AX99100 PCIe to Multi I/O Controller (prog-if 03 [IEEE1284]),
If there are known cards I could buy I’d rather buy a known working card.
This is for a CNC machine, so just the first step of many.
Thanks,
Ted
Thanks,
Ted
Time to create page: 0.767 seconds
