PCI and PCI-E add on cards with parallel port that work out of the box
  • Topic Author
  • Moderator
  • Moderator
2 years 3 days ago #313941 by tommylight
Post only tested and verified cards, with a closeup of the chip used.
For issues with add on cards, start a new topic.
Thank you.
I am posting each card in it's own post so we can add additional info about what mode the cards support, like OUT, IN, X, EPP, ECP, etc.
The following user(s) said Thank You: ContinenteCNC
  • Topic Author
  • Moderator
  • Moderator
2 years 3 days ago - 2 years 3 days ago #313942 by tommylight
PCI-E to parallel, works out of the box, usually address is 0xd020, no complaints about "no parallel port found" from LinuxCNC 2.10.
Can be found only on HP desktop PC's, computer repair shops should have plenty, comes with the short bracket as pictured, price 10-15 Euro here.
Chip seems to be SUNIX SUN2212
It does support SPP, tristate and EPP
Last edit: 2 years 3 days ago by tommylight.
The following user(s) said Thank You: ContinenteCNC, sk_linuxcnc
  • Topic Author
  • Moderator
  • Moderator
2 years 3 days ago - 2 years 3 days ago #313943 by tommylight
PCI to parallel, very old, bought online.
Works out of the box with LinuxCNC from 2.5 and above, several in use for over 10 years without issues.
Uses the MOSCHIP MCS9865 chip, comes with the short bracket.
  • Topic Author
  • Moderator
  • Moderator
2 years 3 days ago - 2 years 3 days ago #313944 by tommylight
PCI to parallel card with 2 of RS232 serial port headers.
Can be found on older HP desktops, hard to find as most have been thrown to trash, but do check local repair shops, they might still be on the shelves...
Works out of the box with LinuxCNC 2.7 and above, can do OUT and IN mode, did not test X mode yet.
Comes with the long bracket and another long bracket with two serial ports.
  • Topic Author
  • Moderator
  • Moderator
2 years 3 days ago - 2 years 3 days ago #313945 by tommylight
PCI to parallel card, same as above in everything except the chip naming is different.
Can be found on the same older HP desktops as the above.
Works out of the box in same modes as the one above.
  • Topic Author
  • Moderator
  • Moderator
  • Platinum Member
  • Platinum Member
2 years 3 days ago #313973 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic PCI and PCI-E add on cards with parallel port that work out of the box
Whilst this is a great topic I fear that newbies will ignore it, I tried the same thing a year or 2 ago. Hopefully having your name as the OP will have more success.
  • Platinum Member
  • Platinum Member
2 years 3 days ago #313974 by Cant do this anymore bye all
Regarding Lenovo ThinkCentres this is the low profile part number for a cable 45j9598
Prices can vary from USD $10 - $20, may seem on par or a little more than a physical card, but way way easier to setup. Beware a std 2x13 to db25 cable will not work as there is the cable would seem to short a pin or some other such trickery that I just haven't looked at. what happens is that the Super IO chip, lacking a better description, is informed there is a cable attached and then enables the Parallel Port setup in the BIOS.
Below is a link to an example.
www.ifixit.com/products/45j9598-lenovo-parallel-cable-280mm
If you have a ThinkStation and want a simple solution and don't want to have a Black Mass under a full moon, unless of course you're Norwegian and you have a bent for a particular genre of Music, this is the way to go. If you are one of the above mentioned, you still can have your Black Mass and use the cable.
  • Topic Author
  • Moderator
  • Moderator
2 years 3 days ago #313978 by tommylight
Where is it?
I did search for that and another one with "duzie" in the tittle but could not find them, strange as i did find the "duzie" one a few days back!
I can try to gather all those into one topic, and yes i am aware this would be better in the wiki, but i do not need anymore logins, have to much as is.
Will delete this post and other "non related" later as we get a chance to read them.
  • Platinum Member
  • Platinum Member
2 years 2 days ago #313981 by Cant do this anymore bye all
Keep this one, it has pictures and less "techno babble". :)
Time to create page: 0.078 seconds
